Old 10-07-2006, 12:50 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Shifter indicator alignment
Did the column shortening yesterday- Thanks Putter- worked out nice except the shift indicator is WAY off. Searched and found nothing.
What did I f-up? How do I get it back in alignment?
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-07-2006, 03:17 PM   #2
Aarons72s
Re: Shifter indicator alignment
In the engine room you have the rod that goes from the ransmission to the colum. Where the rod connects to the coloum there is the bolt that holds it to the colum. Losen it up and drop the bolt further down the rod until you get it where you wnat it.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-07-2006, 03:18 PM   #3
purple gas
If I remember, on mine I did some adjusting where the column arm thing meets the linkage. Kind of a 2 person job. One in the cab puts the lever on the indcator spot, the other under the hood slides the linkage shaft and then tightens up the " bolt with the hole ". With the motor OFF from underneith you can listen / feel for cliks in the tranny to see if it's hitting the geer selection points. Fine tune as neccesary. Hope this helps.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
