Old 10-14-2006, 08:42 PM   #1
abadsvt
abadsvt's Avatar
Rear Shockwaves. Installing at an angle?
I installed the new 4 link but ran into a little problem. I installed the lower brackets just like you are supposed to but the shockwave is really close to the frame rails. I am sure it would be okay but don't want to take a chance. I was thinking about making a different bracket and installing the shockwaves at an angle and wasn't sure if this is okay? Am i not going to get the full amount of travel because it is at an angle? I thought since both would be angled the same wouldn't they cancel each other out and have normal travel? I think that makes sence . I would like it to be still very functionable. Thanks ahead of time!
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-17-2006, 06:52 PM   #2
Beyond Static
Re: Rear Shockwaves. Installing at an angle?
As long as the angle isn't too drastic, I dont see it being a problem.
Beyond Static is offline   Reply With Quote
Old 10-17-2006, 07:50 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Most Shock Co's say no more that 28 degrees. Check with Air Ride.
dwcsr is offline   Reply With Quote
Old 10-26-2006, 03:46 PM   #4
craig@ridetech.com
Formerly LSC71
Putting them at an angle will not hurt them. You will want to keep them at 25degrees or less and both at the same angle. You will not lose any travel either.
craig@ridetech.com is offline   Reply With Quote
Old 11-08-2006, 12:35 PM   #5
Tony@AirRideTech
Junior Member
yup..... in fact you are better off mounting them at an angle.......
Tony@AirRideTech is offline   Reply With Quote
Old 11-09-2006, 12:37 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
C/mon dude tell us more. What's the reason that angle is best?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-09-2006, 02:17 AM   #7
leftcoast66
leftcoast66's Avatar
Tell more please... Is it because of the twist on axle under acceleration and deceleration?
leftcoast66 is offline   Reply With Quote
Old 11-09-2006, 10:48 AM   #8
Tony@AirRideTech
Junior Member
It is because when you mount them at an angle you are actually putting them in a slight motion ratio against the vertical path of the axle. So you are effectively giving the chassis a mechanical advantage over the shocks. By doing that you are broadening your tuning window plus you are increasing the articulation throw of the suspension. That is why you will hardley ever see a manufacturer mount them vertically in a 1:1 ratio....
Old 11-10-2006, 04:34 PM   #9
Col Clank
good to know.
Col Clank is offline   Reply With Quote
Old 11-10-2006, 07:15 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks Tony...
Articles-
"Refining Sierra"
Old 11-13-2006, 12:29 PM   #11
Tony@AirRideTech
Junior Member
no problem man.........
