Old 10-31-2006, 08:52 PM   #1
qksilver
67 292 1/2 ton 4X4
Anybody have any pix of a 292 in a 67-72 4X4. Trying to piece back together a 67 and putting a 292 back in it. Need some pix of frame/engine mounts and brackets plus maybe a/c and p/s brackets etc.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 11-01-2006, 06:24 AM   #2
vtblazer
vtblazer's Avatar
Re: 67 292 1/2 ton 4X4
Not any of those specific areas but this one is 100% original, hope it helps.
vtblazer is offline   Reply With Quote
Old 11-01-2006, 06:14 PM   #3
TP from Cntl PA
TP from Cntl PA's Avatar
Thanks,
Steve
See the post of my truck on this board.........I can get some detailed pictures of the Inline P/S bracket I made if you need it.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 11-02-2006, 11:29 PM   #4
Rod
dont have much for optioned 292's but this one was in a 68 4x4.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-04-2006, 09:32 PM   #5
qksilver
Thanks guys, every little bit helps, it looks like the mounts I have, I think they came off of a 250 will work.
Tp that would be great. i have a set off of a later model 250 (nova) but they won't bolt up.
Vt thanks, that is the air cleaner I am looking for, I have the one for a non P/B ........
This truck has so many different year parts on it and I am trying to get it all 67 correct looking.
I want to do one truck, factory and this is it.
Thanks again guys
Steve
Old 11-05-2006, 01:05 PM   #6
TP from Cntl PA
Here are some pictures of the powersteering pump bracket I made, granted mine is a 250, but the same bosses should be drilled/tapped in a 292 for you to go from. I used the one on the front of the head, and another on top along the side where the intake/exhaust openings are..............I used fairly heavy stock which were scrap pieces I brought home from the machine shop I was working at. It is extremely solid with just those two bolts. I cut the bottom the the GM bracket off, welded it on the bottom of mine, and added a piece of square stock on the top with drilled and tapped hole for belt tension adjustment.
Old 11-05-2006, 01:11 PM   #7
TP from Cntl PA
Here is one I took today of the air box I made to move the air cleaner housing out away from the brake booster............Needed to adapt to the 4 brl anyhow, so I went with the big 14" cleaner housing as well. Of-course the 292 will have more hood/engine clearance problems, but gives you an idea. I still have to finish the welds and paint this yet. I didn't want to do that first and then the hood not clear it But all is well and that will be done in the next week or so. Haven't decided whether it should be GM Orange or Black.
Old 11-05-2006, 09:17 PM   #8
qksilver
sweet, thanks for the pix, I lucked out by having a three grove pulley on the balancer
Old 11-06-2006, 07:09 PM   #9
TP from Cntl PA
Yeah, I am running a 1-wire Alternator and it only has a one grove pulley, so I couldn't drive mine off the crankshaft..........Had to run the one from the crank to the waterpump and the Alternator like a stock Inline without PS, and then run a belt from the other water pump grove to the PS pump. So far its working good, whether it will or not when it gets some miles on it remains to be seen.
Old 11-06-2006, 11:49 PM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
250 & 292 PS are different: brackets, pulleys & more.
Here is a correct set on a 69 292.
PICKMUP is offline   Reply With Quote
Old 11-08-2006, 08:32 PM   #11
qksilver
For sale? A/C ? LOL
Pm me.
Thanks,
Steve
Old 11-12-2006, 05:31 PM   #12
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
You might try to PM Board Member ks147j111928 for Pics of a 292/4 speed + Transfercase setup. It looks as tho he has this setup in his 67 1/2 ton 4x4 minus maybe the power steering & a/c kinda stuff. Worth a shot to see if it helps you...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 11-12-2006, 08:36 PM   #13
qksilver
Thanks, i will
Old 12-01-2006, 11:43 PM   #14
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
Here's the driver's side engine mount
Attachment 228185
...and the passenger side mount.
Attachment 228186
Right side T case mount
Attachment 228188
along with the left side.
Attachment 228189
The T case is a Rockwell T-221 if you are wondering.
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 12-02-2006, 11:55 AM   #15
qksilver
thanks
pix by pix, part by part I am getting closer
