Old 11-03-2006, 10:48 PM   #1
shane72_383
shane72_383's Avatar
Gas gauge wont work!!!!!
The gas gauge in my 72 custom deluxe absolutley refuses to work. Its stuck at like a little over half a tank. I've had the cluster out numerous times and have installed aftermarket gauges for the bottom three and a tach in the middle. Im not sure if it has ever worked, i wanna say that it did before i took it out but im not sure. Just looking for some advice on what to check/replace, thanks a lot. Shane
shane72_383 is offline   Reply With Quote
Old 11-03-2006, 10:58 PM   #2
boogie67
boogie67's Avatar
Re: Gas gauge wont work!!!!!
Did you check to see if it had a ground wire?I had to run a grd. when I changed out my cluster.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 11-03-2006, 11:19 PM   #3
shane72_383
A factory ground wire hooked up? Or have to add one? Why would i if i just plugged it back in? I dont have any clue
Old 11-03-2006, 11:56 PM   #4
A.P.
Black 72 Chevy
A.P.'s Avatar
One quick check you can do to see if it works is disconnect the single wire from the gas tank sending unit. The meter should go to full. If you short the wire from the sending until to ground, the meter should read empty.
A.P. is offline   Reply With Quote
Old 11-04-2006, 12:00 AM   #5
shane72_383
And if all that goes as planned, what would be the problem? Sending Unit?
Old 11-04-2006, 02:38 AM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
Sending unit.
Old 11-04-2006, 02:45 AM   #7
manimal
manimal's Avatar
A.P. is right just backwards. disconnect the power wire to the tank,the guage will fall to empty(no power),then ground the wire and the guage will read full.(do all this with the key on) If the guage does not change readings then you either have a bad connection(doubtful)or the guage is faulty.If the guage does change readings then the sending unit /float could be the culprit.-Sorry A.P. not trying to step on your toes!
manimal is offline   Reply With Quote
Old 11-04-2006, 04:12 AM   #8
A.P.
Black 72 Chevy
A.P.'s Avatar
manimal thanks for the correction, it been a long time since I worked on the electrical on my truck.
A.P.
Old 11-04-2006, 10:06 AM   #9
jamon8
jamon8's Avatar
check the resistance at the tank
check the resistance at the fuse box connection
check the resistance at the back of the cluster connector
it should be between 0-90
0-empty
90-full
jamon8 is offline   Reply With Quote
Old 11-04-2006, 10:40 AM   #10
manimal
manimal's Avatar
Not a problem A.P.
Old 11-04-2006, 10:48 AM   #11
Green Machine
Green Machine's Avatar
Actually AP is right
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-04-2006, 11:05 AM   #12
manimal
manimal's Avatar
Green Machine and A.P. you are both right, I just went and checked my 72 and you are right -MY SINCERE APOLOGY! My experience with troubleshooting fuel guage problems are from working on the old ford cars and trucks that I buy and sell. VERY SORRY AGAIN!
Old 11-04-2006, 12:11 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
More info here.
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-04-2006, 03:02 PM   #14
shane72_383
Thanks a lot everybody i'll have to try that.
