Old 12-14-2006, 03:26 AM   #1
itsbetteratthetop
HELP! 64, need to get ignition out.
anyway. i bought a new wiring harness and key and all that noise, and i need that damn key out. and i dont have a key.
so yeah. my streering wheel is a tilt wheel, i dont know if that matters, but someone was telling me that 64s werent avail with tilt, so i might be sol. haha let me know, im lost.
itsbetteratthetop is offline   Reply With Quote
Old 12-14-2006, 09:34 AM   #2
04Xrider
Registered thread killer
04Xrider's Avatar
Re: HELP! 64, need to get ignition out.
Depending on what year the column is will depend on how the key cylinder comes out, most of the locks in columns have the release inside, which means you will need to pull the steeringwheel to get to it. If you just want to get the key out, try a hack saw blade. Just trim the smooth side of the blade down till it is pretty thin, and you should be able to fish it out.
04Xrider is offline   Reply With Quote
Old 12-14-2006, 10:29 AM   #3
slepysal
slepysal's Avatar
if it is drivable take it to a looksmith they can get it out.
slepysal is offline   Reply With Quote
Old 12-14-2006, 11:07 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Are you talking about the stock 64 ignition or are you talking about a steering column ignition?
Chevy Fleetside is offline   Reply With Quote
Old 12-14-2006, 11:09 AM   #5
poorboy
poorboy's Avatar
If the key is in the colum you can pull the wheel and remove a phillips head screw and it will come out. Some you will need to remove the lockkplate. It's held in place by a lock ring. It's actually really easy. Auto Zone should rent all the tools you ned.
poorboy is offline   Reply With Quote
Old 12-15-2006, 04:03 AM   #6
itsbetteratthetop
yeah, ill have to take the time to take some pictures tomorrow to show you what im talking about
Old 12-18-2006, 02:38 AM   #7
poorboy
poorboy's Avatar
Did you get it out?
Old 12-18-2006, 05:12 PM   #8
itsbetteratthetop
no, sure didn't. i dont know have key for it. and i have no clue what the hell is going on. haha.
Old 12-18-2006, 09:57 PM   #9
poorboy
poorboy's Avatar
On a 64 isn't the key in the insert? Can you take the whole dash insert out?
Old 12-19-2006, 01:05 AM   #10
itsbetteratthetop
um like i said in the first post, i dont think its a standard 64 ignition. mines on the steering colum.
Old 12-19-2006, 05:38 PM   #11
Eliasj123
Have you tried a lock smith?? Cost me about $15 when I lost the keys to my "55 Chevy Sedan... They made me 2 keys and it only took about 15 minutes from the time the guy started, to the time I walked out the door...
I was soo bummed because I lost the ORIGINAL keys.. They were paper thin and worn down to almost just a stub..
Anywho, lock smiths have master keys. They'll try one, then the next one, then the next one, then the next one, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next, then the next.......
You get the point...
Elias
Eh-lee-us
or "E"
Eliasj123 is offline   Reply With Quote
Old 12-19-2006, 11:01 PM   #12
poorboy
poorboy's Avatar
Then it should be like i put in the other post
