Old 12-22-2006, 01:09 PM   #1
dcpetty
dcpetty's Avatar
Air Bag System
Is there anyone using air bags with schrader valves and no compressor or valves? I'm wanting to do bags for strictly ride height only. Once I get it where I want it ,it will be static. What are the pros and cons? Merry Christmas!!
dcpetty is offline   Reply With Quote
Old 12-22-2006, 01:39 PM   #2
abadsvt
abadsvt's Avatar
Re: Air Bag System
What would be the purpose of this? I guess you could do that but what happens if you have a small leak or the bags looses a little air how are you going to fill it up? I think it would be better to buy a small compressor and the min amount of valves so you can air it up if you need too. Are you trying to do a budget install? Good luck!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 12-22-2006, 02:45 PM   #3
Shane
Shane's Avatar
Re: Air Bag System
Mine is on Schrader valves while it's in the "build" stage. I see no problem with it and haven't had a problem with leaks due to the fact that there are fewer connections.
With that being said, the truck will have on board compressor and tanks when it's back on the road. In my mind, the whole purpose of having the air bags is the adjustability in ride height.
If you are truly looking for a static drop, then check into drop springs. Less money and less headaches.
Early Classic would be my recommendation.
Shane is offline   Reply With Quote
Old 12-22-2006, 02:46 PM   #4
GREENCHEYENNE
New Member
GREENCHEYENNE's Avatar
Re: Air Bag System
i have this set up on the rear only of my 71. Its been this way a little over a year and works fine. I bought one of those cheap bicycle tire compressors for about $15 and keep it under my seat. The only problem I have had is if you put any amount of weight in the back you need to add air, and with the little compressor it takes a few minutes.
GREENCHEYENNE is offline   Reply With Quote
Old 12-22-2006, 03:37 PM   #5
jimmydean
jimmydean's Avatar
Re: Air Bag System
Pack a bike pump and get a workout while you're at it.
jimmydean is offline   Reply With Quote
