Old 12-23-2006, 03:29 PM   #1
Jerry8168
Jerry8168's Avatar
how hard is it to switch cabs?
ok heres my problem i have the 2 trucks a 66 chevy long bed and a 66 gmc short bed.. i the gmc has alot of floor rot and i want to keep the chevy logo's and stuff but i need to switch cabs and i was woundering how hard it would be?
Jerry8168 is offline   Reply With Quote
Old 12-23-2006, 05:20 PM   #2
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Re: how hard is it to switch cabs?
changing cabs isn't that difficult.........but aren't the chevy and gmc dashes different???????? hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 12-23-2006, 06:26 PM   #3
Jerry8168
Jerry8168's Avatar
ya i think it is a little bit im staying with the chevy one
Old 12-23-2006, 06:36 PM   #4
krue
Designated A-hole!
krue's Avatar
I don't know if there's any differences between the years, but my 70 was a piece of cake, but I removed the front clip which made it easier. It's a good chance to replace the cab and radiator core mounts.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-23-2006, 06:42 PM   #5
Jerry8168
Jerry8168's Avatar
ya i plan on doing that also i am switching the front grill and head lights
Old 12-23-2006, 09:08 PM   #6
Chevy230
Thumbs up Re: how hard is it to switch cabs?
I have a 65; changed the cab to a 66. fit right up. The GMC and Chevy dashes are different if my memory is correct. Only thing; you need to keep the original serial number from the old cab & put on the cab you are installing on the frame. Some state motor vehicle departments get very touchy about this. Good luck-----
Chevy230 is offline   Reply With Quote
Old 12-23-2006, 09:27 PM   #7
Jerry8168
Jerry8168's Avatar
well thats the problem the frame and i wanna use i don't have papers to but it is a short bed like i wanted
Old 01-08-2007, 03:26 AM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
Now Days Older Cars And Trucks The Dmv Know Most Of The Time The Frame Is Bent Some Time During Its Life You Can Do 2 Things One Gring Off The Old Seril Nb# Offand Restamp It On The Frame Or Cut The Old Plate Off And Cut Yours Off And Reweld It To The Frame I Like The First One Better And How To Do It Make Friends With A Guy That Has A Car Lift The Ones With The Arms It Make Life So Much Easyer
stsalvage is offline   Reply With Quote
Old 01-08-2007, 01:52 PM   #9
Demmit_Hemmit's 65
Does Anyone Know If A Chevy Dash Insert Will Fit In A Gmc Dash???????????? I'm Not Sure But I Know They Are Different...............hemmit
Old 01-08-2007, 05:05 PM   #10
Rogue 64
Ol' Blue Viking
Isn't the 64-66 the same with a round guage panel?
I know 60-63 GMC have a single hump dash and C-10 have double hump.
They can be changed, I'm putting a Double Hump in my '64 now.
Looks sweet, but I still need to work the ends.
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 01-09-2007, 04:37 PM   #11
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
The GMC dashes '60-'66 are the same, with 1 hump, just the guage clusters were different. Chevy guage cluster will not work in a GMC dash. Any '63-'66 truck cabs are interchangable (1/2 ton) the 3/4 ton rear cab mounts use a different rubber mount.
The '63-'66 GMC frames have leaf spring rear end setups, and chevy's had trailing arms '60-'66. The good thing about having the leaf spring setup in the rear on the GMC's, you can mount just about any rearend right up, and be done.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
