Old 01-18-2007, 05:24 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
A rear end question
Today I was under my truck cutting out my old rotted muffler...
I tried the "mark the driveshaft and spin the tire" trick to see what gears I have... the drive shaft turned 1.5 times to 1 revolution of the tire. what does that mean? whats my gears
Next question: my axle seems to be aftermarket, here are the numbers next to the cover... CN1 (upside down) K138 on the driver side and L3 stamped on the pass side. what do i have?
thanks
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 01-18-2007, 05:53 PM   #2
BowTieOgre
Re: A rear end question
thanks
I know when I pulled my rearend out I counted each half revolution of the diff to each full revolution of the tire. It came out to a little less than 4 so I think I have a 3.73 and it sounds like yours might be a 3.08 if that is possible. Maybe someone will sound off to confirm.
FYI my rearend was a non posi.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 01-18-2007, 06:23 PM   #3
Solver
Solver's Avatar
Only way to tell ratio by axle numbers is to get the numbers off the top of the axle tube passenger side. takes a little wire brushing to see them but they are there. with those we can tell you what it originally had in it.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-18-2007, 06:47 PM   #4
jimmydean
jimmydean's Avatar
Mine says right on the glove box sticker "3.73 Gear ratio" or something
jimmydean is offline   Reply With Quote
Old 01-18-2007, 06:52 PM   #5
msgross
msgross's Avatar
mine doesn't say it but it has 3.73's. My front axle had a tag on one of the bolts and the back axle will have numbers on the ring gear (but you have to take the diff cover off) never hurts to change oil anyway! Once you have those numbers there is a chart with the teeth count that will answer your question without a guess...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-18-2007, 06:55 PM   #6
1969k10stepside
On the ring gear look for these numbers,compare the numbers to ones listed below to find ratio.Example:41,11 on the ring gear means 3:73s.
Ratio 2.56:1 - Tooth Combination 41,16
Ratio 2.73:1 - Tooth Combination 41,15
Ratio 3.07:1 - Tooth Combination 43,14
Ratio 3.08:1 - Tooth Combination 40,13
Ratio 3.08:1 - Tooth Combination 37,12
Ratio 3.31:1 - Tooth Combination 43,13
Ratio 3.36:1 - Tooth Combination 37,11
Ratio 3.42:1 - Tooth Combination 41,12
Ratio 3.55:1 - Tooth Combination 39,11
Ratio 3.73:1 - Tooth Combination 41,11
Ratio 4.10:1 - Tooth Combination 41,10
Ratio 4.11:1 - Tooth Combination 37,9
1969k10stepside is offline   Reply With Quote
Old 01-18-2007, 06:59 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
with an open diff, don't you need to turn the wheel twice?
That would come out to a 3.07, which is what comes in a small block/auto truck.
Old 01-18-2007, 07:11 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
I'd say you have 3.07 or 3.08. Mine has a little stamped metal tag attached to the lowest bolt that says 41:11 3.73-1 .
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-18-2007, 07:16 PM   #9
Boise69
The Hammer Man
Boise69's Avatar
OK, i'll check tomorrow when i'm back under there and look for these numbers you speak of. i'll even pull the cover off and look in there too. any recomendations on gear lube to fill it back up with and how much does it take??
1997 MBZ E420
Old 01-18-2007, 07:55 PM   #10
msgross
msgross's Avatar
depends on your rear end and diff cover.... 90W gear oil and 2 qts for a stock 12 bolt but confirm that number first.
The Garage:
Old 01-18-2007, 07:56 PM   #11
Dowdy
If you have a 3.07, which I have, can you put 3.73 gears in that housing? I was told at a car show by some guys who had the same trucks, that you could not.
Dowdy is offline   Reply With Quote
Old 01-18-2007, 07:59 PM   #12
Boise69
The Hammer Man
Boise69's Avatar
well this will be interesting. i'll tackle this tomorrow. It has a chrome cover with 12 red bolts
1997 MBZ E420
Old 01-18-2007, 08:25 PM   #13
msgross
msgross's Avatar
drive it around before you empty the oil... better when it a little warm look for chunks of metal in the oil...small shavings are common. I looked in the service manual for capacities and it says "as required"...go figure. Check your operators manual or a haynes manual... good luck. DOn't forget to pick up oil and a new diff seal, little rtv couldn't hurt either
The Garage:
Old 01-18-2007, 08:48 PM   #14
Boise69
The Hammer Man
Boise69's Avatar
torque values on the cover?
1997 MBZ E420
Old 01-18-2007, 09:28 PM   #15
msgross
msgross's Avatar
service manual says 20 ft lbs... like an oil pan drain plug...!
The Garage:
Old 01-18-2007, 10:07 PM   #16
mnunn454
mnunn454's Avatar
Assuming it's a truck 12-bolt rear end, short answer is "No".
However, you can put 3.42's in it.
Reason is 3.73's and numerically higher R&Ps take a different (a #4) carrier while yours (if it's a 3.07) take's a #3 carrier. What you can do is use a ring gear spacer with a 3.73 on your carrier. Another option is buy a "thick" ring and pinon gear set that will do the same thing. These are fine for stock applications but may not be for high performance/racing apps.
Let us know what you find out tomorrow (besides the fact that hypoid gear lube stinks).
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-18-2007, 11:05 PM   #17
Longhorn Man
Don't use straight 90 weight. Get 80/90 gear lube, and if you have the money, get synthetic. 10 times better than the conventional oil.
Old 01-19-2007, 01:12 AM   #18
chopper103in
chopper103in's Avatar
fill it up to the bottom of the fill hole
chopper103in is offline   Reply With Quote
Old 01-19-2007, 12:53 PM   #19
Boise69
The Hammer Man
Boise69's Avatar
chopper you need to make a drive up to rockford with that truck to talk and compare trucks!! oh and help me too
1997 MBZ E420
Old 01-19-2007, 01:12 PM   #20
bobthecop
bobthecop's Avatar
I was gonna say, fill it 'til it starts running out, let run 'til it quits. It's full. BG makes a great synthetic gear lube, look for a shop that carries BG products. I don't think any auto parts stores carry them. Just repair shops.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-19-2007, 04:39 PM   #21
chopper103in
we will have to do that when the weather gets warm and the roads are clean
