Old 01-21-2007, 07:45 PM   #1
ldanny
ldanny's Avatar
gas tank between the frame rails
thinking of doing this how difficult is it and what different options do i have in where i will put the gas in at
ldanny is offline   Reply With Quote
Old 01-21-2007, 08:13 PM   #2
19GMC63
19GMC63's Avatar
Re: gas tank between the frame rails
I would like to know the same thing. Something thats definitely on the to-do list, the saddle-back kinda bothers me.
Also, how good are these kits on brothers, LMC, ect.?
19GMC63 is offline   Reply With Quote
Old 01-21-2007, 11:49 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
I bought the blazer tank set up for my 65 which is basically the kit they all talk about.. It mounts up pretty easy.. I had a fuel cell there before but didn't care for it as it was only 16 gals.. This tank is supposed to be 20.. The hardest part for you to do will be running the fuel line and fill.. You can always go to the wreckers and cut a door out of a truck and weld it to your truck or you can put a cap in the bed of the truck. Just make sure you have gas before you load it all the way up.. You can see a few pictures here of mine but it is not finished yet... http://s49.photobucket.com/albums/f2.../The%20Trucks/
Chevy Fleetside is offline   Reply With Quote
Old 01-22-2007, 12:47 AM   #4
kwkenuf
Retrofit Management
kwkenuf's Avatar
The Blazer tank bolts up easy. The only problem is figuring out how to fill it. Thru the bed or modify your fender for side fill. I chose the latter. But I drove it around for a few weeks with the filler hose poking up thru my bed until I got around to modifying my fender....
Here it is mocked up
And the gas door
My retrofit fleet
-1966 Suburban 2002 Tahoe drivetrain, firewall, floor, chassis and interior in progress
-1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
-1968 Camaro 95 LT1/4L60E lots o' mods Web Page
-1961 Corvette project Corvette Corrections frame, C-4 suspension and brakes, 02 LS1/T-56, Never ending body workPics
kwkenuf is offline   Reply With Quote
Old 01-22-2007, 01:00 AM   #5
19GMC63
19GMC63's Avatar
that looks good. So how did you route the filler tube in comparison to the frame rail/suspension and what-not?
Old 01-22-2007, 01:04 AM   #6
kwkenuf
Retrofit Management
kwkenuf's Avatar
Like this
Fuel fill and door are from a mid-70s Suburban
My retrofit fleet
Old 01-22-2007, 10:37 AM   #7
49studebaker
49studebaker's Avatar
Kwkenuf, That filler door looks awesome! Same plans I have for my fleetside. I hope mine comes out looking as good.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 01-22-2007, 01:43 PM   #8
kwkenuf
Retrofit Management
kwkenuf's Avatar
Thanks, the whole truck is still kinda rough but it's my daily driver and function has definitely ruled the day over form... I never seem to finish my projects with paint and interior.....
My retrofit fleet
Old 01-22-2007, 05:18 PM   #9
SkylineNXS
SkylineNXS's Avatar
Remeber his truck is also a stepside, so the fleet is gonna be a little different. I am also starting to think about the frame rail tank becuase, well mainly, i wanna move the other one to put some subs in, lol. Not exactly the best reason, but for anyone with one in the cab still, does it stink up the cab at all or is it mostly ok? LMC claims in their little shpeal about their bed tank that the in cab ones smell up the cab. I have yet to hook up mine, so i don't know if it does or not. LMC is selling their kit with sending unit and straps and such for 200.00. Good price?
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 01-22-2007, 09:46 PM   #10
ldanny
ldanny's Avatar
mine doesnt smell at all except when u fill it up but after a couple of minutes it goes away i looked at the LMC tank kit it said some fabrication would be required how much fabbing would i have to do should i go with the k-5 tank or the LMC/Brothers kit?
Old 01-22-2007, 11:19 PM   #11
Fastrucken
Junior Member
Fastrucken's Avatar
Well I went a different route. I'm going fuel injection and an in tank pump was a must. Went to the JY and found a pretty decent setup. 93 chevy van and it has to be atleast 20 gal and has a fuel pump in the tank. I had to move the rear crossmember back about 3" and take a 1/2 in off of both bottom fram rails but fits like a glove. Ill post some pics when I get back into it later this week.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 01-23-2007, 12:05 PM   #12
1lowdiesel
1lowdiesel's Avatar
anyone ever done a suburban tank?
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 01-23-2007, 12:48 PM   #13
Chevy Fleetside
They are kinda too big.. I have a burb tank and the thing is huge... a 1/4 tank on that put 1/2 a tank in my 20gal tank on my 4x4... I know you can use a later model blazer tank but you have to remove the rear crossmember and cut some of the rear sill of the bed out also to get it to fit.....
Old 01-28-2007, 09:25 PM   #14
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
I still have the in cab tank in mine as well as a couple saddle tanks, but I use the in cab tank most often and have never smelled gas in the cab unless I overflowed the tank when filling.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 01-28-2007, 10:45 PM   #15
stepside66
stepside66's Avatar
I got a 16 gallon plastic fule cell with the sending unit for right about 100$ and I just cut off the rivets on the rear crossmember and I am putting it there and just moving the crossmember to the other side and welding it back in here is a pic of what I removed and thats the fuel cell
stepside66 is offline   Reply With Quote
