Old 01-22-2007, 05:10 AM   #1
Slonaker
Insert Witty Text Here
Slonaker's Avatar
C30 Tubular Exhaust Manifolds on C10?
My 350 is running the old 305 exhaust manifolds. I was looking around a junkyard Saturday, and found a C10 with tubular exhaust manifolds. I looked up a pic of the ones they put on the C30s, and it appears to be the ones.
Has anyone used these on a C10? Would my A/C bracket bolt up okay (it bolts to the exhaust manifold)? Is it safe to assume they would perform better on the 350 than the 305 manifolds? Do they have any problems with leaking?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-22-2007, 04:53 PM   #2
Slonaker
Slonaker's Avatar
Re: C30 Tubular Exhaust Manifolds on C10?
I believe they are stainless steel. They looked like this:
Slonaker
Stock '01 Silverado
Old 01-23-2007, 12:39 AM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
Dang I like those, are they factory or aftermarket??? kinda look homemade but probably just as good as a set of shorties.
John
Malo83 is offline   Reply With Quote
Old 01-23-2007, 10:10 AM   #4
Slonaker
Slonaker's Avatar
AFAIK they are factory...
Slonaker
Stock '01 Silverado
Old 01-23-2007, 01:28 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Are they for a SB or BB? Do they have a part #??? would like to get my hands on a set
John
Old 01-23-2007, 02:49 PM   #6
Slonaker
Slonaker's Avatar
For smallblock. I don't know if there is something similar for a bigblock.
Part # 674530 right side
Part # 674531 left side
$241.79 each in stainless steel at www.rockauto.com
Not cheap! I need to try to get the set from the local junkyard. I think they would be okay on the truck, and pretty afordable.
Slonaker
Stock '01 Silverado
Old 01-23-2007, 03:31 PM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
I don't think those will scavenge/flow much better than stock manifolds if even at all, but they'd be a ton lighter and more resistant to corrosion. If you can pick them up cheap at a salvage yard I say go for it.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-23-2007, 03:40 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
Thanks Slon, they are a bit pricey and for that amount I could get a set Thorley Tri-Y's which I really want, might have to check out the local Pick Apart yard, what years were they available on???
John
Old 01-23-2007, 06:18 PM   #9
Slonaker
Slonaker's Avatar
I have no idea when they were available. The only time I saw them was on an 80s C10 in a junkyard. I had heard they came on big pickups, but never saw one until a few days ago. I found those by searching rockauto.com for an '86 C30.
Slonaker
Stock '01 Silverado
Old 01-23-2007, 06:33 PM   #10
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I have seen a set on a 85-86 3/4 ton, I think it was a hd 3/4 ton though. It had factory dual exhaust 2 or 2.5 in don't think it had any catalytic convertors. The exhaust tubing also had like a heat shield around the exhaust pipes. Kind of like the heat shields on a universal catalytic convertor. I'm thinking the engine was a 350, th400, 14 bolt ff rear. I was looking at buying it but that was a really long time ago. That is the only truck I have seen them on out of all the engine bays Ive seen.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-23-2007, 07:31 PM   #11
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
I have a set of those manifolds, i just have not had a use for them. Mine came of a 85 3/4 ton that was some kind if goverment truck.
BIGCHEVYMAN is offline   Reply With Quote
Old 01-23-2007, 07:32 PM   #12
84 400
Sb 400 club
84 400's Avatar
looks like a nice buy from a pick and pull if they are the right price. they are stainless which is sweet!!! but i don't know how much better they can flow. Well should be better then the 305's i think. How much i don't know. Are you planning on running new exhast from thos manifolds to the car? i do not know if the stock y pipe will bolt up.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-23-2007, 08:35 PM   #13
Slonaker
Slonaker's Avatar
Yes, I am looking at getting a whole new exhaust system built. I keep chasing leaks around on mine, and the cats are starting to break apart. It was junk when I got it, and it didn't get any better over the last 5+ years.
It has some really poor quality bends, plus a couple of spots where they just cut a V in the tubing and welded it back together at an angle to make a rough bend of sorts, kind of an L shape.
I found out when I last replaced the gasket at the pipe/manifold that the inside diamerter of the gasket is only 1 7/7, whcih seems kind of small for a 350.
Slonaker
Stock '01 Silverado
Old 01-23-2007, 11:05 PM   #14
84slopwaggin
84slopwaggin's Avatar
Why not just get some nice quality headers along with high flow cats? You would definetly feel a big difference with the torque output.
84slopwaggin is offline   Reply With Quote
Old 01-23-2007, 11:56 PM   #15
84 400
Sb 400 club
84 400's Avatar
good point 84! Slonaker that is one fine truck you got there. If you do headers i would go SS or ceramic coated. But i am guessing you want to retain the stock style?? Eather way are you going to do some sort of duals or just keep her stock looking and sounding? if i ever do mine i havve a whole idea set up. I am going to put a electric cut out infront of the cat and the muffler. so normally the exhaust will flow through the cat and muffler but when i am at a show the electric buterfly opens and the exhaust flows past the cat and muffler and then ties back in after the muffler to the tail pipe. IT is a idea but i think it would be really cool when i am done.
sorry for the off topic rant
1985 C10 LWB Sold
Old 01-24-2007, 12:27 AM   #16
84slopwaggin
84 400 let'em hang, man. Just let that cutout dump under the truck. It will sound awesome. I see no reason to route the exhaust around the cat and muffler. I've heard that high flow cats flow tremendously well, with little to no restriction on the system. I'd would use 2.5 exhaust along with the high flow cats. HEADERS+2.5 STAINLESS EXHAUST TUBING+2HIGHFLOW CATS+2SUPER40FLOWMASTER MUFFLERS=AWESOME SOUND AND PERFORMANCE
