wheel backspacing
ive got a set of 15*8 sunrasier type rims fitted with 33/12.50's,but they stick out too far.they have got about 2.75" back space.how much more back space could i give it without having to grind the front calipers too much?how much is every one else running?thanks
Re: wheel backspacing
You can go up to 4"s of back spacing and be fine.
3.75" to 4" of back spacing seems to be 'the' good all around fit. |
#3 | |
do you also have to grind any off the backing plate/cover on the disc? |
I`ve put 8-lug 10x15 white spokes (whatever std backspacing is)on a `71 K/20.I just had to grind the caliper at it`s hi-spot along it`s radius at the casting seem.
