Old 02-07-2007, 10:31 PM   #1
dilling
inner roof panel above w/s
I see you can get now. Has any one put one in. It looks like it has a flange on it is it made to be lapped against old panel(on the side away from windshield). I think I would butt weld it in. I on the fence how I would take care of a truck with rust in this area beacuse there not access to back side to sandblast/treat to stop. I might just cut out wrost looking area and replace then use long tube on my rocker gruad gun to spray somthing up in there .
dilling is offline   Reply With Quote
Old 02-07-2007, 11:23 PM   #2
Re: inner roof panel above w/s
It`s the header panel.Get the part,look it over,and decide where to go from there.
Old 02-08-2007, 12:42 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Once you cut out that area to put in the patch, you have all the room you need to treat existing rust. This is on my list of to-dos. Looks labor intensive, but not too complicated. From what I've read, the hardest part is getting the piece in place above the doors...
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-08-2007, 12:59 AM   #4
dilling
yhea but once you cut you have removed all the rust, the inner panel is the one that rust. If there was a way to blast it to get rid of rust from inside I would not have to replace. I not good with words so I I have hard time saying what I mean
