Old 08-27-2002, 09:42 PM   #1
Mountain Man
Question about dip stick tube in engine block
I have a new chrome dipstick set. The tube into the block seems to just push into the block hole. Before I damage the stock one, removing it. Does it just pull out of the hole in the block, maybe by using some vise grips?
I tryed wiggling the stock one on the weekend , and it seemed to be firmly in place. I don't want to twist and pull until I know that it is o.k. to do so.
Also , does the new one just press in, and seal o.k. with no silicone?
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 08-27-2002, 10:14 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
theres a trick to pull one out, and i forgot how its done now, hmmmm
have learned too much new lately and forgotten some old....
well, one way is to get a bolt or piece of rod that will slip into inside of top of the tube and get rags around the tube and use vise grips and try that way,, or something similar, when you renistall then you need to use long screwdriver or punch on the lip at the base of the tube down there to drive the tube down, if its kinda not real tight fitting then use some RTV black on it,
good luck
Fast68Chevy is offline   Reply With Quote
Old 08-27-2002, 10:16 PM   #3
RainDog
RainDog's Avatar
It should just pop out (assuming mine were all meant to), I wouldn't bother with any silicone unless it keeps slipping out or moving around.
RainDog
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats."
RainDog is offline   Reply With Quote
Old 08-27-2002, 11:10 PM   #4
RipMeyer
RipMeyer's Avatar
I have twisted them out with pliers. They are supposed to be a bit snug and should require a little force to get them out.
RipMeyer is offline   Reply With Quote
Old 08-27-2002, 11:24 PM   #5
junkyardjohn
junkyardjohn's Avatar
Thumbs up
YEP ... I JUST LATCH ONTO IT NEAR THE BLOCK WITH VICEGRIPS, TURN BACK & FORTH & PULL UP. I LIKE TO PUT A LITTLE SILICON AROUND THE NEW ONE JUST BELOW THE BULGE, DROP A 3/8" BOLT INTO THE TOP END, & TAP IT INTO PLACE IN THE HOLE UNTIL IT SEATS.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-27-2002, 11:37 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
I have used a 1/2" wrench to seat the new tube also. Slide it over the tube and tap on the wrench with a hammer until it is seated.
As far as removal. I have just wiggled it and it will slide out as you pull.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-28-2002, 01:44 AM   #7
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
yep, i agree with da-burb.....wiggle the old one out, use pliers if nescessary, and put a wrench over the tube, rest it on the lip and smack the wrench with a hammer.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
