Old 02-11-2007, 01:18 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Booster Question.....
Ok I just picked up a 3/4 ton booster and master cylinder off a 70 pickup with disc brakes. I want to intstall it on my 71 1/2 ton with disc brakes. Do I have to use the 3/4 ton master cyl or can I use the "new" 1/2 ton cyl that is on my 71? Also what about the proportining valve? Will the one on my 71 work or do I need to get one for a 3/4 ton? Anything else I need to know for the swap? TIA.....
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 02-11-2007, 01:22 PM   #2
msgross
msgross's Avatar
Re: Booster Question.....
pretty sure that you need a 3/4 ton MC with the booster. Prop valve should be good if it's for disc/drum but the lines will need switched. 3/4 and 1 ton lines are reversed from 1/2ton, so I have been told.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-11-2007, 01:22 PM   #3
Aarons72s
You did get the brackets that 3/4 booster mounts to, right? If not go get them if you can you will need them along with the rods to if I rember reading correctly. The 3/4 ton master cylinder has to be used with the3/4 booster. Some one tried to mix a 3/4 ton booster with 1/2 ton master cylinder and it didnt work. Not sure on the proportioning valve but someone will chime in.
Aarons72s is offline   Reply With Quote
Old 02-11-2007, 01:25 PM   #4
Draggn66
Draggn66's Avatar
Yes the booster is complete with the rods and the firewall brackets
Now the 3/4 booster is an upgrade right? Duel diaphram?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 02-11-2007, 01:30 PM   #5
Aarons72s
Yes alot better than the 1/2 ton one is.
Old 02-11-2007, 03:38 PM   #6
msgross
msgross's Avatar
This is what I am planning. I have the 1 ton brackets, booster and MC but my booster has fluid coming out of the vacuum line! Looks like I have a core with a good set of brackets. I am redoing all of my brakes as well and adding discs. Very popular and economical upgrade.
The Garage:
