Old 02-13-2007, 03:59 AM   #1
shrtbx
did 86 trucks come with true duals or a y pip set up
Did 1986 chevy trucks come with a true dual exhause with 2 cats. Or a single y pipe set up. The guy i bought the truck from just has separate pipes from each manifold going to two cheap mufflers.
shrtbx is offline   Reply With Quote
Old 02-13-2007, 09:08 AM   #2
ocbaud
Garage Queen Material
Re: did 86 trucks come with true duals or a y pip set up
stock they came with 2 cats and a Y pipe setup with the pipe exiting on the side behind the passanger rear tire.
i believe thats how it is.
ocbaud is offline   Reply With Quote
Old 02-13-2007, 09:26 AM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
1/2 or 3/4 with light duty emissions, v8 gas engine - Single exhaust with two pipes from muffler back both exiting driver's side (not passenger).
3/4 or 1 ton with heavy duty emissions (no cats) duals with exits on both sides.
Diesels - duals exiting each side.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 02-13-2007, 03:46 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Gracho is right on ,Y-pipe to single exhaust, my 83 came that way and I would run the true dual exhaust like you described, had a friend of mine pull the exhaust pipe at the manifolds and run duals with 40 series Flows, when it came time to smog I would throw the original exhaust back up, the older I got the more of a hassle it became so now i'm running a single 3" exhaust with a 3" cat and 3'' in and dual 2.5 out Flowmaster dumped in front of the axel
John
Malo83 is offline   Reply With Quote
Old 02-13-2007, 05:38 PM   #5
Duro5341
Duro5341's Avatar
2WD, or 4WD....?
My 86 4X4 came with 350 HD emissions, had a y-pipe with 1 cat, and single outlet on drivers side, behind rear wheel
Duro
Duro5341 is offline   Reply With Quote
Old 02-13-2007, 07:18 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
My truck 84 GMC Sierra Classic and the son's 86 Silverado came with a "Y" pipe and a single catalytic convertor under the passenger side. This went to a single muffler and then out the passenger side at the rear fender. That did not last long in my world. There are headers, a connection underneath to a "H" pipe and then to dual Flowmaster mufflers and out the back through "MEGS" stainless tips. We don't have smoggies here.
The upgrade would be to use a "X" crossover pipe, rather than the "H" design, but I will wait for old age to take out the pipe first.
piecesparts is offline   Reply With Quote
Old 02-13-2007, 08:40 PM   #7
shrtbx
whats a good set up smog legal headers for california.
Old 02-13-2007, 08:45 PM   #8
swervin ervin
You get what you pay for
swervin ervin's Avatar
I don't think any of our trucks that came with a cat had the cat on the passenger side. I know my 85 came with a y-pipe and the cat was on the drivers side.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-13-2007, 10:23 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
I can't vouch for the later trucks but that makes sense. The frame has a "flare" in it to accomodate the cat on the drivers side. I don't think they ever changed that.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-14-2007, 08:15 AM   #10
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: did 86 trucks come with true duals or a y pip set up
I bought an '85 new and it was set up as a Y pipe into a single cat and then into a muff and dual out and exit the driver side.
I also bought my '87 new and it was exactlly the same set up as the '85.
So i don't think Chevy would of changed the entire exhaust system for one year and put it on the other side or as dual set up.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-14-2007, 12:10 PM   #11
piecesparts
My son's truck and mine both were on the passenger side. I know this very well, since I had to remove all of the damnable metal shielding along with the cat in my changes to the trucks.
Old 02-14-2007, 09:35 PM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
True duals is the only way to roll. Got no smog testing up here so nothing to worry about.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-16-2007, 11:06 AM   #13
87 STEPPER
87 STEPPER's Avatar
Question Re: did 86 trucks come with true duals or a y pip set up
What years are they?
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 02-16-2007, 05:54 PM   #14
piecesparts
Mine is an 84 GMC Sierra Classic SWB and his is an 86 Cnevy Silverado SWB.
Old 02-16-2007, 07:51 PM   #15
Curly86
You want it there when???
Curly86's Avatar
My 86 Silverado has got a Y pipe no cat goes into muff and comes out dual and one pipe goes out each side
Curly86 is offline   Reply With Quote
Old 02-16-2007, 08:25 PM   #16
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Everyone I have seen that was stock. Has the manifolds, y pipe, then catalytic convertor on the driverside, intermediate pipe, over the axle pipe and then muffler with dual tail pipes on the driverside.
I did seen a hd 3/4 ton. It has stainless steel manifold but more like shorty headers, dual pipes down each side, not catalytic convertors, two mufflers, tail pipes 90ed behind the tires.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-16-2007, 09:41 PM   #17
84 400
Sb 400 club
84 400's Avatar
On my 85 it was Y pipe, then ran dowm the drivers side into a cat and then a muffler and then exit in two pipes coming out be hind the drivers side rear tire. That was stock.
on my 84 the y pipe and pipe ran down the passangerside into a cat then a muffler.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
