Harmonic Damper for Goodwrench 350
I am installing a new Goodwrench 350. The harmonic damper off my original 305 is galled in the sealing area so I am going to replace it. Also, the original timing marks on the 305 chain cover are in the 12:00 position which is different than the bolt on timing marks that came with the new 350.
The local NAPA store can get me a new harmonic damper that fits a 77-86 350. LMC also sells a 350 damper for 77-86. Is that the right harmonic damper? I want to make sure the TDC/timing indicator matches correctly with the damper.
