Old 02-18-2007, 12:50 AM   #1
dave2953
Dave's not here, man
dave2953's Avatar
ECE Super Track Bar
Tonight I was installing my Super Track Bar. When I went to bolt the bar to the PS bracket it looks like the bolt will hit the axle when it's fully tightened. I have ECE's 5" drop springs and i'm running the bolt through the upper hole in the bracket. Did I do something wrong? Tech Support won't be open 'til Monday, but I need the truck before then. Thanks in advance for you help.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-18-2007, 12:59 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: ECE Super Track Bar
I just installed one yesterday... there should be no issues with the bolt contacting the axle tube. Can you post a pic?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 02-18-2007, 12:12 PM   #3
Joe67
67 is sold
Mine is running through the bottom hole and does not contact my axle with a 6" drop.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-18-2007, 12:20 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
A quick fix would be to drop the bracket and install the bolt through the other direction with the nut on the outside. Then re-mount your bracket. The only draw back I see would make it hard to pull the bar off. But I don’t think that will be a problem.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 02-18-2007, 06:20 PM   #5
dave2953
dave2953's Avatar
I just got home from work and I'm going out to mess with it in a few. I Sport Truck, I thought about that but the instructions specify that the bolt be installed facing the rearend, although I'm not sure why. I will try and get a pic if I get out there before dark. Thank you all for your help!
EDIT: After I torqued to bolt, the only thing that interfered was the brake line. I just pulled it out of it's clip on the axle and shifted it upwards a bit, and everything is good.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 02-19-2007, 01:52 PM   #6
Joe67
67 is sold
Good to hear.
the only reason I can see htem recommending the bolt mount 'inwards' would be for maintenance like SportTruck stated.
