Old 03-06-2007, 10:08 PM   #1
DangerBoy
Leaky 68
I've got a problem. My truck is leaking way too much oil. I noticed it this weekend when I came to a stop and there was some smoke comming out from under the cab right after the header collectors. I cleaned things up and narrowed it down to my passenger side valve cover gasket that wasn't sealing good. I changed that one and drove it again today. There was some improvment, now instead of throwin out 2 quarts every 30 miles its down to 1 quart every 30 miles. I inspected the valve covers and theres no oil comming from there. I checked the oil pressure line and fitting and noticed some there so I cleaned it up and retightened it. My distributor doesnt seem to have any leakage around it and the hold down is good and tight. I'll have to wait till tomorrow to see if its any better or worse. Anyone have any ideas? Pkease help.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 03-06-2007, 10:38 PM   #2
cabinetguy
67 shorty
cabinetguy's Avatar
Re: Leaky 68
You said when you put on the brakes so I would check the pan gasket where it meets the timing chain cover. This is a problem area.
67 SWB with enough parts to build two
cabinetguy is offline   Reply With Quote
