Old 03-11-2007, 08:23 PM   #1
tylermckee
Whats the problem here?
Have a 454 in a 87 p30 chassis. Engine seems to idle fine when you first fire it up, after a few minutes the idle kicks down and it seems to idle normal, has about 20# vacuum and holds steady. Then after running 10 minutes or so and getting fully warmed up it just wants to die, wont keep running unless i give it some throttle. Otherwise it will just bog down and die.
What are some of the things that could be going on here so i can run through and check everything.
tylermckee is offline   Reply With Quote
Old 03-11-2007, 08:51 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Whats the problem here?
adjust the idle screw more then all is well.
Srubydo1986 is offline   Reply With Quote
Old 03-11-2007, 08:57 PM   #3
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Sounds like it could be flooding out too. You can look down int he top of the carb and see if it's pouring too much gas into the engine.
xtreme80 is offline   Reply With Quote
Old 03-11-2007, 09:01 PM   #4
tylermckee
I forgot to add that it also runs pretty rough when this happens, so i dont think its gonna be that simple.
Old 03-11-2007, 09:11 PM   #5
Srubydo1986
The Crazy Machanic
well then i got nothin that i can think of cause all the vaccums are good, correct?
Old 03-11-2007, 09:15 PM   #6
xtreme80
xtreme80's Avatar
Or better yet, RIGHT AFTER it dies the first time, look down into the top of the carb. Is it really wet? Can you smell alot of gas in there?
Old 03-11-2007, 10:19 PM   #7
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
wiht all the temp based vacume switches and the 91' of vacume line i would bet that you have a open end somewhere or bad and old lines.
trkklr77 is offline   Reply With Quote
Old 03-14-2007, 04:07 AM   #8
tylermckee
I've been replacing all the vacuum lines as they are all old and rotten. I just didnt understand the whole only dying when its warm thing
