03-18-2007, 01:38 PM | #1 |
Flip Kit Questions
I would like to know when you do a flip kit and noth the frame, do you have to cut the bed floor at all?
I would also like to see some pics of the flip kit installation if anyone has them. Thanks, Ryan
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
03-18-2007, 02:07 PM | #2 |
Re: Flip Kit Questions
I have a Western flip kit installed and all I have to say is that I had to work on my bed in combination with an 2" habger. Pics are availible at www.los-lowrider.com then on tech-corner
03-18-2007, 02:26 PM | #3 |
Street Rod Restoration
best i have for now, 4 1/2 and 6" drop, the answer is no.
Follow me on Instagram @ hot_rod_shop |
03-18-2007, 04:46 PM | #4 |
i put a flip kit on my 86, no notch, rides fine. I don't haul anything in the bed either, and drive like a granny.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
03-18-2007, 05:09 PM | #5 |
i dont haul with my truck either, but i do let people know it has a posi from time to time
03-19-2007, 03:08 PM | #6 |
www.73-87chevytrucks.com
for a flip kit you don't have to do anything to the bed.
If you put shackles on you would though.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 03-20-2007 at 06:51 PM. |
03-19-2007, 03:14 PM | #7 |
mine's flipped and c notched with no bed mod's.ride's ok.i don't haul or pull nothing with it.i suppose it's load limit isn't much.but if your looking to drop it.i doubt your going to use it as a work truck anyway.
" Never look up a dead dogs butt." |
03-19-2007, 04:51 PM | #8 | |
exxxxactly
03-19-2007, 05:03 PM | #9 |
Mad Scientist
My bro's 81 is flipped. Factory spring pack, shackle, and hanger. No notch and no issues. Ran 9.50's in the thousand ft. without issue.
Everythang relates to Beer! 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
03-19-2007, 06:10 PM | #10 |
You get what you pay for
If you use Western Chassis C-section, you will have to notch a tad on the bed. It has bolts on the top and they will hit. At least they did on mine.
http://www.73-87.com/7387garage/chas...n/csection.htm
Mike 1985 Chevy C-10 |
03-19-2007, 06:47 PM | #11 |
yeller
Hangers no, shackles yes.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-19-2007, 07:19 PM | #12 |
Ya like bigblock73 said... but it dosent hurt well you are there to do it, just for future... I did mine with just a peice of 6 inch pipe cut in half and alittle bit of metal to box the frame in a bit.
03-20-2007, 06:51 PM | #13 |
Oops, that is what I meant. Gotta proof read these... thanks Jeff.. I corrected it...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-25-2007, 04:14 PM | #14 |
Do you have to notch the frame for a 5" flip also? Or just a 6"?
86 GMC C15 swb. 350/TH350, fully loaded, but wish I had overdrive! |
03-27-2007, 10:42 PM | #15 |
so if i just do a flip on my truck, i could get away without notching the frame?
03-27-2007, 10:50 PM | #16 |
Wishin' I had more money!
You probably still wanna notch your frame. Even if the axle doesn't hit the frame under normal driving conditions, there's always that big bump, pothole, railroad tracks, etc. You will bottom out the axle on this stuff, and it's not fun, and could lead to damage.
03-27-2007, 10:56 PM | #17 | |
tis true. thanks
03-27-2007, 11:02 PM | #18 |
"It's easier to modify now what will piss you off later!"
-quote Jessie James
03-27-2007, 11:07 PM | #19 |
no sense in doing shizzle twice
03-27-2007, 11:07 PM | #20 |
______________
Here's my F150 with a flip kit.
Or wait, no, it just had over 1000 bricks in the bed. And no people, I did not drive it like this. |
03-27-2007, 11:12 PM | #21 |
03-27-2007, 11:12 PM | #22 |
helluva kit
03-28-2007, 01:45 PM | #23 |
The Crazy Machanic
Iv donwe that before tomy old 86 c10 I was at a stop light that had a slit hill. The truck had a granny tranny so i put it in low to give it that extra goo for the wieght. Well when the light turned green my truck went up Before i started to go the truck did two full stand on the bumper. Need less to say i think that the cause of the rear going out and the tranny fork breaking off later on.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
03-28-2007, 04:04 PM | #24 |
needin' money
we put about 1500 lbs. worth of gardening dirt, and stuff in the back of mine, it had that nice flip-kit only like appearance
SWB Stands for Short Wide Bed |
03-28-2007, 04:17 PM | #25 |
______________
ttt
