Old 03-21-2007, 12:37 PM   #1
skeet85silverado
Electric fuel pump ?
I just installed procomp red electric fuel pump on my truck the pump works great but i keep making a buzzing noise. Does a electric fuel pump suppose to sound like all the time? Do i maybe need to install a regulator with it. It says it doesn't call for one on most models.
skeet85silverado is offline   Reply With Quote
Old 03-21-2007, 12:40 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Electric fuel pump ?
Most elec pumps make a humming/buzzing sound....some more than others. Adding a regulator will not help the noise issue.
bigblock73 is offline   Reply With Quote
Old 03-21-2007, 12:52 PM   #3
skeet85silverado
It's pretty load? I can hear it over my exhaust
Old 03-21-2007, 01:01 PM   #4
bigblock73
yeller
bigblock73's Avatar
I hear Holly elec pumps are about that loud too. If you want elec, you either have to spend some good money for a quality pump, or live with the noise I guess. I dont know too much about them.
Question, why did you abandon your mechanical setup?
I almost did on my truck, but decided to stick with a mechanical unit. I figure there are guys running 9's, 10's in the quarter mile with 10.5 inch tires and mechanical pumps...there is no reason for me to...especially since I will only be in the 12's.
Old 03-21-2007, 01:01 PM   #5
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Remove the pump and mount it to a rubber plate, kind of like a muffler hanger.
What you're hearing isn't so much the pump but the vibrations through the truck. Isolate the pump from the truck and the noise will go away.
One thing, though. If there's currently only one wire going to the pump you're going to have to fabricate a grounding strap for it.
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 03-21-2007, 01:05 PM   #6
bigblock73
yeller
bigblock73's Avatar
Excellent suggestion, never thought of that.
They still will make noise, every elec pump car I have heard has a noisy pump...but like I said, some more than others.
Old 03-21-2007, 01:28 PM   #7
skeet85silverado
I installed a 350 out of a 93 suburban and it doesn't have a mehanical setup.
Old 03-21-2007, 01:39 PM   #8
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
it should of had the plate over the hole were the pump goes. Or did they remove it intirely.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-21-2007, 01:43 PM   #9
skeet85silverado
This was a fuel injecton block where mechnical fuel goes is just metal
