03-29-2007, 11:17 PM | #1 |
how to get a 1/2 ton to sit up like a 3/4??
i want my 1/2 ton to sit up like a 3/4 like this......
03-30-2007, 11:44 AM | #2 |
Re: how to get a 1/2 ton to sit up like a 3/4??
we are all about lowering here
03-30-2007, 03:56 PM | #3 |
well then dont input if your not helping
03-30-2007, 08:35 PM | #4 |
Chill out Nothing personal most members here make silly comments for fun. I would think you could raise it with either 3/4 ton springs or if you have leafs in the back you could add shackles.
03-30-2007, 08:56 PM | #5 |
so put it on a 3/4 frame ...
p.s. you're not gonna make many friends with the pissy attitude. |
04-02-2007, 03:39 PM | #6 |
Too many projects
2wd or 4wd?
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-02-2007, 05:15 PM | #7 |
its 2wd all im worried about is the front right now. the back will be blocked to level it out
04-02-2007, 05:34 PM | #8 |
do you know how much higher it is that you want to go? fabtech makes a 3" lift coil for 73-87 2wd trucks.
04-09-2007, 11:20 PM | #9 |
Check out the fabtech kit, its about 640-750$, a little costly for some you might also check and look at the truckin mag and see the ads for lifts of 3". I went the fabtech route but havent installed the kit yet, waiting till i replace the entire front suspension next month. One of the few C-10s with a fuel injected V8 and 30MPG!!
t rex |
04-10-2007, 02:46 AM | #10 |
Hello check around an get you some heavy duty springs or call ece or cpp they have all kinds of springs but a 3/4 spring will ride harsh
nickle and dime |
04-10-2007, 10:46 AM | #11 |
Find a local spring shop to re-arch your springs.
On my 70 4x4 3/4 ton, I paid $491, tax included, for one day service to have the springs re-arched and have an add-a-leaf 2" lift front and rear. I will never worry about axle-wrap due to rear blocks. For the cost, you can't beat it. Plus, aftermarket springs are usually sloppy, and you will find that you cannot use as large a tire as you thought, and you can really get bouncy. The drawback is a stiffer ride, but better road handling, and your wheels will not droop as deep into gullies when you cross them.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. Last edited by martinkh; 04-10-2007 at 10:47 AM. |
04-10-2007, 11:30 AM | #12 |
Junior Member
Just order replacement springs for a 3/4 ton........ The only thing I would think you might want to double sheck is if the leaf springs are the same length from eyelet to eyelet.
