Old 09-04-2002, 10:01 PM   #1
diehardrider
KEEP IT PINNED
BB in 4x4 header
I have a BB in my 71.
What would be a header with a good chance of fitting?
Im going to go through autozone for easy returns if they dont fit
thanks
RYAN KING
71 swb 4x4
diehardrider is offline   Reply With Quote
Old 09-05-2002, 12:58 AM   #2
71BBK10
Teufelhunden
71BBK10's Avatar
i don't know about the other members here with bb's in 4x4's but on my passenger side header, 2 of the tubes that go into the collector had to be "massaged" to clear the front driveshaft. not sure what kind of headers they are though so it may not be like that for all sets. good luck.
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 09-05-2002, 08:29 AM   #3
Pont
I need another Barley Pop
Pont's Avatar
Hey Ryan, just don't buy cheap headers. You'll be happy you spent a few more bucks.
I'm running Hooker headers however, your 71 will have better fitting headers than my 67. Almost all header manufacturers should make a set for your truck. I had to cut about 4" from the length at the collector on the passenger header for mine to fit. You should haven't have that problem.
Good luck and keep us posted on what you go with........
Rob
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 09-05-2002, 02:11 PM   #4
diehardrider
KEEP IT PINNED
thanks for the replys.
ya ill buy a header with a thick flange and something that will last.
Do they make a header for the big block swap?
or do u just get it for a 2wd truck or what?
thanks
RYAN KING
71 swb 4x4
Old 09-05-2002, 05:52 PM   #5
Pont
Pont's Avatar
They do make headers for a big block in a 4x4 from 69-87 trucks. Should be a fairly standard part # from most major header manufacturers. Hooker, Hedman, etc.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 09-07-2002, 12:31 AM   #6
DaHateTank
Did you see my reply, in the other thread (Header Advice)??
Originally posted by DaHateTank
I used the Hedman engine swap headers, when I put the 396 in my '72 Blazer. Had to put a SMALL notch in the right framerail, to clear the tube. The frame bulges out there, anyway. If the framerail was straight (ie. like a piece of channel iron) it woulda fit OK. The notch is REALLY mild, if ya didn't know it was there, you wouldn't see it (unlike the notches shown in the caddy engine threads )
My engine is moved forward an inch, to gain firewall clearance. (I don't like the hammer tactics.) If it was in the stock position, they mighta been OK w/o the notch, or maybe required a small ding.
On the other side, I had to put a ding in one tube, to clear the motor mount. I used the stock 350 mounts, big block spool mounts might have cleared.
Despite all these things, it took a whole 30 minutes, to change the headers, when they rusted out (about 7 years). all in all, Ive had alot worse times, with car headers, that were used in 100% the application they were listed for...
They were pretty cheap, and I actually was pleasantly suprised, by the fit...
Recently, I looked at a '80s Suburban, that had a 454 swapped in, He used Hooker Super Comps, and they looked to fit pretty good, as well... Im pretty sure his engine is in the stock location, with factory parts (He has a couple big block parts trucks)
HTH
-M
Also, I had to make up some pretty tight bends, to clear my trans crossmember. I used Hooker mandrel bends, 180 degrees, cut in the middle of the bends, reversed and welded.
Further, my clutch linkage is mostly custom fabbed, so I don't know how well the stock clutch linkage would work. Hedman says the stock BBC pieces will clear. I didn't have them, so I can't vouch for this...
The Hedmans are cheap ($99), but seem to fit and work pretty well, IMO...
have fun
-M
DaHateTank is offline   Reply With Quote
Old 09-07-2002, 02:28 PM   #7
diehardrider
KEEP IT PINNED
Thanks for all the info.
Now all i need to see is what i can afford.
I will try to get the highest quality though
thanks
ryan
RYAN KING
71 swb 4x4
Old 09-11-2002, 07:53 AM   #8
MOTHERTRUCKERS
We sell the dynomax headers for bb 4x4 trucks and have never had a complaint on fit or quality, our hooker and hedman headers need a little dimpling to fit 4x4.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
