Old 04-07-2007, 03:48 PM   #1
fishuntr
Standard bed vs. Super 10 bed
We have a 78 Chevy C20 with Super 10 decal on bed. Tape reveals it is about 5" longer than standard 8 ft. bed. The bed is real beat up and the question is; will a standard 8 ft bed fit? Appropriate years etc. Gas cap openings same?
72 C-20,LB,350, 4spd, 1 owner
fishuntr is offline   Reply With Quote
Old 04-07-2007, 08:02 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Standard bed vs. Super 10 bed
Ummm, I am pretty sure (99.9%) there were only two bed lengths available, 8 foot and 6.5 foot. I would double check your measurements, and post pics if you can.
I would go out on a limb and say 100% sure...but I have been wrong and learned new things from others here on the board...so I won't go there.
bigblock73 is offline   Reply With Quote
Old 04-07-2007, 08:08 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
id think they will theres no way gm would make a different frame for one kinda truck. Gm is a frieght company (everything matches up with other cars).
But me id find a way to repair that bed only cause it would be unique.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-07-2007, 10:21 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Pyrotechnic is offline   Reply With Quote
Old 04-08-2007, 01:30 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I have to agrre with you Jeff, if your wrong then so am I. GM Didn't build an 8'5" bed for 73-87s
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-08-2007, 09:20 PM   #6
bigtruck81
i wouldnt be so sure it didnt exist... remember the Longhorn's from 68-72? could happen, could be aftermarket too. i'd like to see pics of it.
FWIW, a cab and chassis frame would work rather good for the extended wheelbase if that's how the extra length was created.
bigtruck81 is offline   Reply With Quote
Old 04-08-2007, 09:57 PM   #7
fishuntr
Red face Re: Standard bed vs. Super 10 bed
Well, I guess I should have investigated this a little further. I measured another bed on a truck of this vintage, and it was the same. I guess It depends on where you measure. Soooo...I posted too soon; before my brain was properly engaged. Sorry guys. I still would be interested in what the significance of the "Super 10" on both sides of the bed.
Here's what I know about the truck. It has been parked for 10 years. Had big rat's nests on top of the engine. All the wiring is chewed up. Odometer shows a little over 70,000 miles. Original owner recently deceased. He bought the truck new in Pennsylvania, drove it to CA. It was some kind of camper special; has fancy built-in tie downs to the frame. Owner only drove it occasionally, and parked it.
I had seen the truck for many years, and when the old man died, I spoke to his son who lives in L.A. He essentially told me to "get it out of here"; which I was happy to do. I pulled it to my shop, pressure washed the engine clean, pulled the plugs and soaked the cylinders overnight with Marvel Mystery Oil. Changed the oil/filter, put new plugs/wires on, drained the fuel and put in fresh; put new battery in. Since all the wiring is trash, I jumped the starter and ignition wire. It started right up, and, after a huge cloud of smoke cleared ran good. The auto trans shifts back and forth. I haven't driven it because of the tires.
It's going to be a huge project, but the price was right. I have a close friend that wants it. I think I'll stick with my 72.
Old 04-09-2007, 01:44 AM   #8
KIILew
Active Member
You know, it almost sounds to me like the "Super 10" emblem is the second half of the die cast "Cheyenne Super 10" fender badge used on 1/2 ton pre-'75 Chevy trucks equipped with that trim option. Could it be that someone migrated such an altered emblem to the side of your truck?
Just a thought...
Ken Lewis
KIILew is offline   Reply With Quote
Old 04-09-2007, 11:08 AM   #9
fishuntr
Possible, I guess. It is a decal, but doesn't look like an addon. It definitely is a C20. I looked at the rear spring pack and it looks even beefier than my 72 C20. Since we determined it is a standard bed, I found one here in town off of an 84 for $50. It is in good shape and has a good tailgate. we'll go pick it up this AM.
