Old 04-17-2007, 09:52 PM   #1
wpvtx
wpvtx's Avatar
68-72 verses 73 and up front drive shafts
Does any one know if there unversal (interchangable)?
wpvtx is offline   Reply With Quote
Old 04-17-2007, 10:11 PM   #2
1969k10stepside
Re: 68-72 verses 73 and up front drive shafts
The trucks with the 205s(70-72) and some newer models(73-??) had longer driveshafts than the older ??-69 4wds that had the 221 t case
1969k10stepside is offline   Reply With Quote
Old 04-17-2007, 10:38 PM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
I've got to check this one out, I have a front driveshaft from an 87 hanging in the barn, and the u joints are all shot in the 72.....maybe it will fit.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-18-2007, 11:33 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Early model 205's had u bolts to hold the drive shaft to the yoke.
Later model 205's and all the 203's that i saw, had a flat flange to bolt to another flat flange on the TC.
I'm not sure about the early Rockwell case's. But they probley had the u bolt design too.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-18-2007, 12:36 PM   #5
1969K10
1969K10's Avatar
Ol Buck - sorry about your luck, but no interchange...
My Rockwell is U-bolted at both ends IIRC.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
