Alright Alright Alright
I hastily removed the wires and plugs to soak the pistons in deep penitrating lube, and now I forgot how the wires connect to the distributor and block. Rather, I forgot the order in which they were arranged. If anyone can help me with this, I would greatly appreciate it. Pictures might help as well if you have them.
This motor has been sitting for a while, and here's what we plan to do: New plugs and wires New cap and roter Pertronix Ignitor II and Flamethrower II coil (elec. ignition) New fluids, belts, and filters New battery and terminals New Thermostat Valve cover Gasket Re-pack the bearings New tires Rebuild on the 1bbl rochester Carb Minor brake job and bleed Replace Manifold gasket also... What else can be done to get this thing moving, and running well enough to move it around town. We need to get it rolling so that we can take it to do the exhaust, paint, etc... What would you suggest? Finally, we want it running as healthy as possible. How do you set the timing properly? Ideal gap for plugs? Any tune up tips will be much appreciated. I'm sorry for the story. I'm just excited to help my buddy on a cool truck. have a great day.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
| Bookmarks |
