Old 05-09-2007, 04:27 PM   #1
55ChevyPU
55ChevyPU's Avatar
Quick question regarding CPP brake booster
Question- On the CPP brake booster is there a return spring? The brakes work great but the brake pedal just seems to stay semi-engaged. I am thinking either im missing a return spring or maybe the vacuum supply is not strong enough to pull the pedal back out. Maybe I need a vacuum canister? Do you have a vacuum canister?
55ChevyPU is offline   Reply With Quote
Old 05-09-2007, 06:14 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Cal- Quick question regarding brake booster
I konw mine has the orginal return spring still on it..
Brian ..
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-10-2007, 01:23 AM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Quick question regarding CPP brake booster
Funny you should ask. I was having the same problem with mine. Two weeks ago I added a spring to help it return, It works great now. I also had a problem with the adjustment on the small rod that pushes the master cylinder in. It was causing the brakes to drag and I made an adjustment to it and it's working well now.
CAL 58 GMC is offline   Reply With Quote
Old 05-10-2007, 02:57 AM   #4
55ChevyPU
55ChevyPU's Avatar
haha thats funny- how/where did you mount the spring?
Old 05-10-2007, 10:38 AM   #5
CAL 58 GMC
CAL 58 GMC's Avatar
When I get home tonight I'll take a picture and post it.
Old 05-10-2007, 01:53 PM   #6
GATORBUILT '59
GATORBUILT '59's Avatar
Now that is totally AMAZING. I am experiencing all of the above Problems as well.
GATORBUILT '59 is offline   Reply With Quote
Old 05-10-2007, 07:50 PM   #7
CAL 58 GMC
CAL 58 GMC's Avatar
Here's the picture. It's not high tech but it works.
Old 05-10-2007, 10:50 PM   #8
55ChevyPU
55ChevyPU's Avatar
thats pretty much exactly where I just mounted mine- on a side note- there should be an actual mounting point for that brake switch any reason you mounted it where you did ?
Old 05-11-2007, 02:24 AM   #9
CAL 58 GMC
CAL 58 GMC's Avatar
I mounted under the cab to keep it off the fire wall. I also made the switch adjustable by cutting the arm in half and drilling a hole then bolting them together.
