Old 05-20-2007, 06:52 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Replacing vent glass question....
How do you remove the old glass from the vent window frame? I need to rechrome the frame then install new glass. Any help on removing or installing the vent glass would be nice. I have new glass setting rubber tape or whatever you call it. Thanks
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 05-20-2007, 08:24 PM   #2
JimKshortstep4x4
Re: Replacing vent glass question....
I wet the glass/rubber down with a soap solution and then pull the glass out starting at the top. Sometimes I have had to pry the glass out out using a smooth screw driver with rounded edges to get the glass started out.
On installing the glass I apply the tape to the glass, soap it down and then pound it into the frame with a rubber hammer.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
