Old 05-30-2007, 11:17 AM   #1
Hart_Rod
Hart_Rod's Avatar
WTB Carrier bearing bracket
(Picture below) I need a carrier bearing bracket like the one used on the heavier duty trucks, not the light duty ones. The one I'm talking about mounts to the bottom of the trailing arm crossmember not the top. Any help would be appreciated.
Hart_Rod is offline   Reply With Quote
Old 05-30-2007, 11:27 AM   #2
67 cst swb
67 cst swb's Avatar
Re: WTB Carrier bearing bracket
Would a 3/4Ton have one? I may have one if so...
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-30-2007, 11:33 AM   #3
falvarez12001
falvarez12001's Avatar
I have replaced it on my longhorn, and no one seem to have it. Finally bought it at NAPA autoparts. 12 bucks hope that helps.
Why, Because it's my truck
1972 Chevy Longhorn, Dropped 4-7
1984 Chevy Shortbed custom Deluxe (Daily Driver)
falvarez12001 is offline   Reply With Quote
Old 05-30-2007, 11:38 AM   #4
Hart_Rod
Hart_Rod's Avatar
The mount or the carrier bearing?
Old 05-30-2007, 11:39 AM   #5
67 cst swb
67 cst swb's Avatar
I'm understanding that you need the carrier bearing mount, Correct?
My Trucks:
Old 05-30-2007, 11:53 AM   #6
Hart_Rod
Hart_Rod's Avatar
Correct, I added a picture and circled what I'm talking about. Thanks for the replies.
R
Old 05-30-2007, 01:12 PM   #7
67 cst swb
67 cst swb's Avatar
I'm headed out to my parts trucks this afternoon... So, If a 3/4T would be correct, I can pull it off this afternoon...
My Trucks:
Old 05-30-2007, 01:31 PM   #8
Hart_Rod
Hart_Rod's Avatar
If it rivitted to the bottom of the crossmember it is correct. Thanks and let me know.
R
Old 05-30-2007, 02:23 PM   #9
rlm316
rlm316's Avatar
Rob, My C20 mounts from the top. What model are you searching for? I am going to do some work at a local bone yard Sat. and if you let me know I will check out what they have while I am there. Let me know, Lane
rlm316 is offline   Reply With Quote
Old 05-30-2007, 02:28 PM   #10
Hart_Rod
Hart_Rod's Avatar
I'm not sure what model i came on, but it mounts like the picture above.
Old 05-30-2007, 07:19 PM   #11
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Save yourself the trouble guys, I already ground one out for you Rob.
I will get it out to you ASAP. Talk to you soon, Mike
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
Old 05-30-2007, 08:54 PM   #12
Hart_Rod
Hart_Rod's Avatar
Thanks Mike!!
Old 05-31-2007, 12:32 AM   #13
hotrodmtodd
'Burban Legend
That was FUN. It looked like the 4th of July in May! Had to use the little Makita grinder, the big Hitachi grinder and the cut off tool to get that from between all those brackets and stuff! Tim Taylor would be PROUD! Will send it to you as soon as I can Rob. Take care, Mike
'69 C-30 dump
'71 4x4 454
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
