Old 06-07-2007, 09:45 PM   #1
terrellautosports
New Member
terrellautosports's Avatar
Removing and Installing glass in doors
can anyone tell me the best way to remove and install the glass and window regulators back into a door?
found some good doors at junk yard and going to put the glass and regulators in from other door. also the vent window needs removed and installed.
thanks in advance.
terrellautosports is offline   Reply With Quote
Old 06-07-2007, 10:18 PM   #2
LILRED66
LILRED66's Avatar
Re: Removing and Installing glass in doors
Start by removing the door handle and window crank, by removing the set screw, securing it to the spindle with a slotted screw driver. Remove the twelve phillips screws, securing the door panel to the door shell, using #3 bit works the best. A #3 is a square tip/philips tip combined. Now remove the screws securing the window regulator and latching mechanism form the inside of the door shell, exposed when the inner door panel was removed.
The window glass is secured in the window track, via friction fit and glazing tape. Over time this tape tends to become brittle and it shrinks, so the glass will usually pull out of the track without much effort. Once the glass is removed you are able to remove the lock regulator and window regulator. A #3 tip is best for removing the screws holding the regulators, as well.
You can now reverse the process, to install the old regulators into the donor doors. While you have the doors apart, I suggest new glass whiskers (on either side of the glass as the window rolls up), the window channel (on the window side of the vent window), the glass gasket (from the top of the wing window frame across the top of the glass and down into the door shell) and the vent window gasket.
They set looks like this:
http://www.lmctruck.com/icatalog/cbe/0013.asp
I hope this information is helpful and good luck with your project.
Tony
LILRED66 is offline   Reply With Quote
Old 06-08-2007, 12:01 AM   #3
slepysal
slepysal's Avatar
nice job lilred !!!
slepysal is offline   Reply With Quote
Old 06-08-2007, 07:55 AM   #4
terrellautosports
New Member
thanks lilred66
