09-16-2002, 06:16 PM | #1 |
Before and After
Sanding in tight areas
What is the best way to sand in tight areas? Where two panels meet but will be hidden between the cab and front of the box, Should I be worried about this area? Do I need to take it to bare metal?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
09-16-2002, 07:58 PM | #2 |
The best way to sand is to "sand blast her" really the only way you can get in there...
1967 GMC Custom 8ft Fleetside 292 L6, 4spd. 1973 Oldsmobile Delta 88 Convertible 455, TH 400 1969 F#$% Bronco 302, 3spd 4.11's 1958 Oldsmobile Super 88 Fiesta Wagon |
09-16-2002, 11:03 PM | #3 |
Take the box off.
09-17-2002, 12:25 AM | #4 |
i love summertime
i second on taking the box off..might as well do it properly
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
09-17-2002, 08:42 AM | #5 |
1969 Custom 30 wrecker
Since I had to replace my front bed panel, I just removed it and was able to get to the back of the cab. (mine is a stepside but might work on yours too) They are just bolted in so you might try that.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-17-2002, 09:19 AM | #6 |
REMOVE THE BED SAND BLASTING IS A NESS SAND EVERY WHERE BRAKES INSIDE TEETH
09-17-2002, 11:21 AM | #7 |
Before and After
My bed is off, I just don't want to take the bed apart. Any suggestions?
You know where panes meet, and bolts, stuff like that, is it ness to blast?
09-17-2002, 10:05 PM | #8 |
U CAN BACK THE BOLTS OUT SOME AND SAND UNDER THEM...... THERE IS NO EASY WAY TO DO THIS THIS IS Y A PAINT JOB COST MONEY... SAND BLAST THE SMALL AREA IF U ARE STRIPING ALL THE PART.. OR PULL OUT A FEW BOLTS AT A TIME.
