Old 06-18-2007, 03:48 PM   #1
pat
pat's Avatar
Manual lock-out hubs
Ive got an 89 Jimmy, Id like to put some manual hubs on it. How much would these help mileage? Where can I find them and how much should I expect to pay for them?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 06-18-2007, 08:35 PM   #2
rcbildr
rcbildr's Avatar
Re: Manual lock-out hubs
I did a search on Google for Warn Hubs and found a pair for approximately $90. I didn't really notice a change in mileage afterwards.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-18-2007, 10:46 PM   #3
pat
pat's Avatar
http://cgi.ebay.com/ebaymotors/New-S...mZ150087726160
Would I need more than this?
Old 06-19-2007, 12:45 AM   #4
rcbildr
rcbildr's Avatar
I don't think so..other than tools. You will need a set of snap ring pliers and maybe a good set of picks (sp?). One thing you might want to consider when you swap them out is to check (and maybe grease) your wheel bearings and make sure the spindle nut is properly torqued. You will need to buy a spindle nut socket for that...any auto parts store should have one. I ran in to that problem when I installed my hubs, both spindle nuts were very loose.
My Projects:
1978 Camaro Z28
Old 06-19-2007, 04:02 PM   #5
pat
pat's Avatar
Good info
Thanks!
