Old 06-26-2007, 01:47 PM   #1
northerngmc
northerngmc's Avatar
Where do your gauges operate?
Just curious as to where the temp/oil/and volt gauge should be when operating?
My volt gauge sits in the middle no matter what.
My temp gauge will go to about the 12 o'clock position when driving around town.
The oil gauge is about 10:00 o'clock at idle and 12:00 o'clock driving.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 06-26-2007, 01:54 PM   #2
SactoJim
SactoJim's Avatar
Re: Where do your gauges operate?
I've just been recently messing with this.
Have a temporary mech temp gauge hooked up and my factory temp gauge at 12:00 is 180 deg and the first tick into the red is about 200.
The oil pressure gauge reads 60 lbs max (each tick is 15 lbs)
Don't have the amp gauge hooked up yet.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 06-26-2007, 01:58 PM   #3
raoul.duke
Sandwich: Club
raoul.duke's Avatar
My ammeter sits in the middle too but that's cause the leads on the printed circuit is blown up....not gonna fix it either.
Temp gauge sits in the middle or slightly lower unless I'm hauling a$$ on the freeway in the TX summer heat, and then it'll creep up to almost hot.
Oil gauge runs 10 o'clock at idle but probably 2 o'clock under load, depending on the temp of the motor
raoul.duke is offline   Reply With Quote
Old 06-26-2007, 04:52 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
I have a pretty much stock '70 Camaro 350 engine in my 71 C-10 truck. I don't know how many miles the engine or truck have on them.
The amp meter did not move when I first bought it so I replaced both small fuses, now when I first start it the meter moves a little to the right.
The temperature never goes above about 10:00 o'clock.
The oil pressure registers 12:00 o'clock at 2500 rpm and about 10:00 o'clock at idle.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 06-26-2007, 04:58 PM   #5
northerngmc
Thanks everybody, this helps.
Blaine
Old 06-26-2007, 06:04 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
My temp gauge stays right around the center tick mark, a little lower driving around town, a little higher at 70mph. Oil pressure stays in the middle, sxcept at idle, then it goes to the 10:00 o'clock position.
The ammeter normally points straight up, except when cranking the starter, thenit goes to the D mark, and after the engine starts, goes towards the C until the battery gets recharged. Some people don't like ammeter gauges, but I much prefere them.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
