Old 06-29-2007, 12:47 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
HELP!!! Engine misses
I took my truck out for a drive today, and it seems like the engine is missing. I don't notice anything at all at idle, but under a load it surges and misses. no backfire or anything. The engine is a 77 350 c.i. with no emissions stuff. I ran the tank down to a little under 1/4 tank, but filled it back up(trash in the gas?). The spark plug wires are practically new and it ran fine 2 days ago. Can anyone help? Thanks in advance.
Jake
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 06-29-2007, 02:04 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: HELP!!! Engine misses
Sounds like it could be bad gas water or something.
You could try some drygas and run it low again before you fill up.
If the gas is the only thing that changed I would just go over everything and try that first.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-29-2007, 02:09 PM   #3
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Maybe a fuel filter. If it's a quadrajet, beware because you probably have an integrated fuel filter on the carb as well as any additional ones any POs might have put there. It's a small filter and they get clogged easily... basically it'll run fine until you ask it for any power.
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
