Old 07-09-2007, 06:02 PM   #1
BarryB
BarryB's Avatar
I need some measurements.
I need to know the size of the axle size on a 2 or 4wd drive truck. Aslong as it is 6 lug. I need the measurement of the part that sticks out in the center of the brake drum. I am thinking it is right at 3.5" across.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-09-2007, 06:30 PM   #2
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: I need some measurements.
My 4x4 axle is 3.5" across where the center of the drum would slip over.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 07-09-2007, 09:58 PM   #3
BarryB
BarryB's Avatar
Thanks EFI70BLAZER, Cool I just scored some wheels and tires and was curious of the fit. The center holes are just over 3.5" so they should fit right on.
Two rules in life.
