Old 07-24-2007, 04:11 PM   #1
stepn67
Junior Member
stepn67's Avatar
Question Correct Ram Horns?
I picked up a set of ram horn manifolds which I want to use on my 67. The truck is being converted from an I6 to V8 in the V8 location. The rams I got have one dumping stright down and the other dumping angled back. Will these work for my set-up. I don't have the engine in yet so I can't check it out.
stepn67 is offline   Reply With Quote
Old 07-24-2007, 04:29 PM   #2
Mt Man Chad
Mt Man Chad's Avatar
Re: Correct Ram Horns?
If it's a 2 wheel drive they sholud both be angled back.
4 wheel drive manifolds dump straight down.
And 67~68 have a mount on the front edge of the driver side manifold for the alternator!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 07-25-2007, 05:29 PM   #3
stepn67
Junior Member
stepn67's Avatar
My 67 is 2 wheel drive. Does this mean I won't be able to use the center dump manifold?
Old 07-25-2007, 05:49 PM   #4
billtoothaker
Junior Member
I would think you could you might need to incorporate some 4WD exhaust parts that bolt to the manifold, Check and ake sure about the Alternator bracket,though. Good Luck
Bill Toothaker
72 K20 FSLB 63K
FS:86 Mercedes 560SL
63 Ford F100
51 Willy's Jeep station wagon w/64 289 Studebaker
68 Honda SL90 1500 miles
Chevy 6 cyl street rod
2011 Nissan Murano cross cabriolet
Cabins for Rent Lake Winnipasaukee, NH
billtoothaker is offline   Reply With Quote
Old 07-25-2007, 05:52 PM   #5
It seems I`ve seen some 2wds have both curved and some had one center,like a 4wd.
Old 07-27-2007, 07:09 AM   #6
I checked and`67 w/283 called for a center straight dump on the passenger side,the same part as a 4wd.The same for a 327 in 67/68.I think the 307s and 350s had the matching turned dumps.Don`t ask why.I would think they were all interchangeable on 2wds.
