Old 07-26-2007, 09:01 PM   #1
kxnomore
kxnomore's Avatar
water coming out the auto transmission cooling tubes????
I finally got the trans cooler lines from inline tube today, but when I pulled the plugs where they connect to the radiator, coolant came pouring out?
This can't be right, can it? I thought trans fluid ran through that part of the radiator??
Thanks in advance for any input/ advice.
kxnomore is offline   Reply With Quote
Old 07-26-2007, 09:07 PM   #2
Eddie H.
Eddie H.'s Avatar
Re: water coming out the auto transmission cooling tubes????
Sounds like you need a new radiator. The trans cooler tubes in the radiator are leaking. Better to find it now than ruin a transmission.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-26-2007, 09:24 PM   #3
kxnomore
kxnomore's Avatar
Just my luck.
Does this internal water leak negatively affect the workings of the radiator? Should I just get an external trans cooler for now to save money?
I was liking the idea of having the correct stock tubes though. What do you think is better?
Old 07-26-2007, 09:43 PM   #4
Jayss109
Active Member
Jayss109's Avatar
if it gets cold in your neck of the woods, I would use the cooler IN the radiator. EDIT: Get a new radiator first!!! Helps get the fluid warm, and maintains a constant temp when its cold outside. If not, use an external.
my two cents
Jason
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 07-26-2007, 10:36 PM   #5
cdowns
cdowns's Avatar
i guess you could use it asis with external tranny cooler then at the most inoppertune time when the rad finnally craps out completely in the middle of nowhere you could worry about replacing it then
Old 07-26-2007, 11:43 PM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Rad is fairly cheap compaired to the motor and trans I would buy a new one !! My 2 cents !!!
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
