Old 07-26-2007, 11:39 PM   #1
dan42
dan42's Avatar
argh!!
I have hit a little bit of a wall while trying to put the windwing back in my truck. I took it apart, replaced the seal, and now it seems physically impossible to re-install. Do I need to take the windwing out of the window channel and then pop it back in after it's most of the way in? Any suggestions will be appreciated at this point. Hard to drive around like it is now.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-26-2007, 11:41 PM   #2
dan42
dan42's Avatar
Re: argh!!
Here's a couple of pictures -
Philippians 4: 6-7
Old 07-26-2007, 11:47 PM   #3
dan42
dan42's Avatar
Re: argh!!
Here's another -
Philippians 4: 6-7
Old 07-27-2007, 12:30 AM   #4
jhow66
jhow66's Avatar
Re: argh!!
Take you big window off the rear track and slide it back. Install wing and then big window.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-27-2007, 12:43 AM   #5
Green Machine
Green Machine's Avatar
Re: argh!!
I would remove the rear track that the long felt fits in and just slide the window back without removing it from the track, thats how we've done it before, easier I think.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-27-2007, 12:53 AM   #6
dan42
dan42's Avatar
Re: argh!!
Loosen/remove the 3 bolts? I'm having a hard time convincing the screw in the back of the door to come loose. It is fro-zun. I'll let it soak with a litttle WD40 overnight, I guess. But it's those three screws, right? The two just under the panel on the inside of the door, and the one above the latch screws on the back of the door?
Philippians 4: 6-7
Old 07-27-2007, 02:45 PM   #7
Green Machine
Re: argh!!
Yes that is the track I am talking about.
