Old 07-27-2007, 11:37 PM   #1
rcbildr
rcbildr's Avatar
Getting ready to do a 4" lift
While my Burb was in the tranny shop getting fixed (had a major problem with the SM-465) I was told the rear end on my Burb needs to be replaced...I was able to listen to it too and it was not good. I've decided to install a 4" lift when I go to replace the rear end. I already have a good replacement rear end and while I'm waiting for parts I"ve been wondering, will I have to modify my rear driveshaft? Any help will be greatly appreciated. THanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 07-28-2007, 12:20 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: Getting ready to do a 4" lift
You shouldnt have to worry about any driveshaft issues with only a 4" lift, I've never had any problems with mine. What size tires are you going to run?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-28-2007, 08:06 PM   #3
benoit454
Chris
benoit454's Avatar
I put a rough country 4 inch lift on the 86 we had, no driveshaft issues. They both extended out more about 3/4 inch or so. You could see the clean marks on them were they were before and they were out further by about 3/4 inch or so.
It's not a big dal or big isue, you should be fine, unless the driveshaft just doesn't bolt up to the rear end, or it's like alot shorter center chunk or alot longer then your old one.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-28-2007, 10:37 PM   #4
rcbildr
rcbildr's Avatar
Thanks for the info. I'm going to stay with the 33's that are on there now and when they wear out, I may go up to 35's. I can't wait for the parts to get here. Thanks again.
My Projects:
1978 Camaro Z28
