Old 08-05-2007, 10:33 PM   #1
dentmaster
Need help with tires size!!!!
I am restoring my 69 cst blazer, and I am wanting to know what is the biggest tire that I can run with a 6 inch lift. I am not rock crawling, or even off roading. This is gonna be a street only blazer. I was hoping I could put 38's....but i am unsure..... Any help would be appreciated.....
dentmaster is offline   Reply With Quote
Old 08-05-2007, 10:52 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Need help with tires size!!!!
There's a guy near me running 38's and a 6" lift. The suspension is super, super stiff. Even the slightest flex and the tires will rub. 35's are usually recommended with a 6" lift. You can run bigger tires, but you'll probably need to do some fender trimming. The wheel off-set is key too. Also, keep in mind that anything above 35's isn't recommended with the half ton running gear.
Not all 35" tires are 35" tall. I'd do some shopping around to find some true 35's.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-06-2007, 01:05 AM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Agreed.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 08-06-2007, 07:07 AM   #4
vtblazer
vtblazer's Avatar
38's require alot of space, start thinking about more lift.
1/2 ton axles will not have the braking capacity needed to stop those big tires either.
Steering becomes another big issue, more lift mandates changes there to make things safe as well.
Welcome to the board.
vtblazer is offline   Reply With Quote
Old 08-08-2007, 12:50 AM   #5
dentmaster
thank you for your help..
