Old 08-19-2007, 12:27 AM   #1
jmax
lowering blocks
how do you install lowering blocks on a 2002 ext.cab 1/2 ton? all the instructions i have read show the leaf springs under the axle but my leafs are on top does that make a difference?
thanks in advance for your help!
jmax is offline   Reply With Quote
Old 08-19-2007, 12:57 AM   #2
FnLow69
FnLow69's Avatar
Re: lowering blocks
you can't it will lift it, you need drop shackles (i think they make them) or a flip kit witch will give you about 5" of drop
FnLow69 is offline   Reply With Quote
Old 08-19-2007, 01:28 AM   #3
jmax
Re: lowering blocks
thanks thats what i figured but wanted to make sure before taking them back, and i'll look into the shackles thanks for your help!
Old 08-19-2007, 11:37 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: lowering blocks
drop shackles will give you 2" drop. You should be able to get them on in about 30-40 minutes. If you want to go lower than this, next step is to get 2" drop hangers (these are the front leaf spring mounts). Little more work to put them on. A flip kit will net you a full 6".
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
