Old 08-21-2007, 03:46 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Power windows stopped working, ideas?
The power windows are stuck (down of course) in my '83 and I cant figure out why. Power locks still work and all the fuses are good, any ideas what I might be able to do to get them working? I'm going to pull the panel and run a quick jumper to see if the motor works and at least get them rolled up for now, thanks for any tips
Adam
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-21-2007, 03:50 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Power windows stopped working, ideas?
Both of them? Mine stopped working one time on the driver's side only. I hit the door panel (out of anger) and it started working again. That was a cheap fix! Sounds like you might have a loose wire on one of the switches...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-21-2007, 03:59 PM   #3
knightlife
Dark Heart Motorsports
knightlife's Avatar
its either:
a.) loose wire
b.) dead motor
either way are easy fixes...
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 08-21-2007, 04:14 PM   #4
bigblock73
yeller
bigblock73's Avatar
Correct me if I am wrong, but don't the windows run thru a junction block (of some sort), up under the dash? Perhaps that is bad (especially if BOTH windows quit working)? Look under the dash, possibly near the center somewhere...I remember 75 stepside telling me about this a while back...
bigblock73 is offline   Reply With Quote
Old 08-21-2007, 04:28 PM   #5
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Hit the door or slam it hard, happens in my camaro, i guess a loose connection
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 08-22-2007, 07:08 PM   #6
cochino12
cochino12's Avatar
So I ran a jumper from from an 18v drill battery to the motor while the switch was connected and it shorts out. I disconnect the switch and hook up the wire and the motor rolls up/down fine. Did the same on the passenger side and it worked great whether the switch was plugged in or not? I had another switch laying around and tried it and same thing. Maybe both switches are bad?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-23-2007, 12:23 AM   #7
Eyegore
What Hump?
Eyegore's Avatar
Corroide connections perhaps? That is where i would start looking, get some contact cleaner at Radio Shack.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
