I want replace the original sealed driveshaft/rear with an open shaft/rear application. I'm putting a 350 engine / 350TH trans. in the truck, but I don't know what rear to put into it. If anyone could give me some insight on what rearend works best without heavy modifications to it, I would appreciate it greatly. The original rear width is about 51" from back plate to back plate. I'm looking for something with a 5-lug pattern and disc or drum brakes.
I am not positive but I seem to remember people tend to use 70-81 Camaro/Nova style 10 bolt rear ends. I don't know if it is a direct swap or if new brackets have to be welded on the rear end. Sorry I can't help more. I am sure there is someone on the board that has done this swap.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
My 1950 GMC sets on a 1970 chevell rear end but took very little to make it work.
Cantankerous Geezer
The Camaro/Nova (or the Buick, Olds, Pontiac) makes a good swap. It is 1/2" wider and the biggest job is cutting off and welding on spring perches. Several guys at the Stovebolt forum www.stovebolt.com have done this change.
Fred There is no such thing as too much cam...just not enough engine.
| Bookmarks |
