Old 08-27-2007, 08:31 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need help with gas tank options..
What have you guys gone with on your gas tank relocations.... 56 chevy..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-27-2007, 08:44 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Need help with gas tank options..
Here's what I did....
Brian ..
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 08-27-2007, 11:09 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
I s that a fuel cell from summit?
MEMBER #6377
Project "7DEUCE"
Old 08-28-2007, 04:53 PM   #4
entourageguy
Yellow truck club
Summit has a simliar one. This is made by Jaz.
Brian ..
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-28-2007, 11:34 PM   #5
CAL 58 GMC
CAL 58 GMC's Avatar
Mines under the bed. I used Kustom tank's 16 gal tank.
CAL 58 GMC is offline   Reply With Quote
Old 08-31-2007, 11:04 PM   #6
56hotrodred
Where did you get the inner wheel wells? I have a 56 SWB stepside I am early into and was thinking about increasing the width of the rear wheels a little for a bit of that hot rod look. I am also wrestling with where to put fuel tank but was hoping for something a little larger that 16 gallons.
Your truck looks great - what we can see of it.
56hotrodred is offline   Reply With Quote
Old 08-31-2007, 11:32 PM   #7
bfink
i just ordered a 16 gal fuel cell from summit tonight . i really wanted to go w/ a stainless tank but couldnt convince myself to part w/ 5 bill's. my truck is mini tubbed too , i used the inner fenders off of an late 70's early 80's fleetside and trimmed them to about 6" wide
Brian
55 chevy stepside
bfink is offline   Reply With Quote
Old 08-31-2007, 11:48 PM   #8
56hotrodred
Fantastic look! I have never heard them called mini tubs but am going to pursue that more.
I have beeen toying with the idea of a combination marine grade polished aluminum tool box/fuel tank where a guy can get upwards of 30 or more gallons. There is a possibilty that I can mount the battery in the tool box above the fuel tank also. The cost however is through the roof (ca. $1000.00) but it solves a lot of problems with battery, large fuel tank and tool box. It also will weight a bit but I do dislike driving around in an empty truck. I live in rural western Canada where everything is quit far apart - bigger fuel tank is better and i want to make a cruiser.
The fuel cells with sending unit look pretty straight forward and I will really have to weight my options carefully.
Barry
Old 09-01-2007, 09:44 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Has anyone got a tank under the bed with a side filler? Reason being is here in oregon we cannot pump our own gas we has gas jockey that do it for us yes stupid I know but once this thing gets paint I dont want some jockey screwin up the paint..
MEMBER #6377
Project "7DEUCE"
Old 09-08-2007, 01:09 AM   #10
PDW HOTRODS
PDW HOTRODS's Avatar
I'm in Oregon also, and we can pump our own for Classic cars, and
motorcycles if we want. I put a 1970 Nova tank under the back, and
made a gas door under the tail gate. I also made the tail gate shorter
to make room for the gas door.
PDW HOTRODS is offline   Reply With Quote
Old 09-08-2007, 09:34 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Thanks pdw for the info and welcome to the board ....
MEMBER #6377
Project "7DEUCE"
Old 09-08-2007, 10:30 AM   #12
lotussutol
Brian ..
I have a question for you. did you trim that back crossmember and/or move it back some? It looks like you have fresh bolts holding the crossmember in which is why I am asking if you slid it back some.
I was going to order a summit one like that today. I see a few of them in there though and did not measure this morning before heading to work. Oh well, I guess I can order it tonight after I measure the area so I know which one to order.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 09-08-2007, 03:53 PM   #13
bfink
lotus , im putting a 16 gal summit fuel cell w/sender in my 55(i'd be done today but i caught a wicked cold) i had to move the rear crossmember back 2" so the tank will fit . its kind of a pain in the ass to get the bottom rivets out because they also hold on the rear leaf spring hanger too (if youe still using leafs)
Brian
55 chevy short/step
Old 09-08-2007, 04:16 PM   #14
lotussutol
Brian
55 chevy short/step
sorry to hear about the cold. that sucks.
And I am hoping to avoid having to move my rear crossmember back a couple inches. I do not mind trimming the top out some to get it to drop in but I do not want to have to move it.
Lotus
Old 09-08-2007, 06:32 PM   #15
entourageguy
Yellow truck club
Yea I moved mine back as well...
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 09-08-2007, 06:42 PM   #16
lotussutol
Brian ...
quick question...what size back tires are those on your truck?
Lotus
Old 09-08-2007, 08:19 PM   #17
entourageguy
Yellow truck club
Hey
The rear tires are 235/70 15 on 15x7 ralley rims. ! have 2.5" spacers right now to clear the box. I'm planing to do a small tub this winter so calipers clear the box in the wheel wells.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 09-09-2007, 02:04 AM   #18
lotussutol
cool. I have 225x75 15 in the back. With the 8.8 rear I do not think my bed will fit on. My adapters are 1" and convert me over to a chevy pattern. I have some torque thrust wheels I am going to use. I think I am going to try and fit 275x60 15 in the back.
back to the fuel tank. I ordered one from summit tonight. I am going to trim up the back support to get the tank to fit rather then move it since it is attached to the rear leaf area too. That sounds like next weekends project if I can get the rear of the frame notched this week.
Is the rear on your frame notched or not?
Lotus
Old 09-09-2007, 08:24 AM   #19
entourageguy
Yellow truck club
Hey
Yes I c notched it and boxed it as well. Just used some 6" pipe.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
