Old 08-29-2007, 12:42 PM   #1
Kopper
Factory Engine Oil Cooler
I purchased an 85 1/2 ton for parts and it has a factory engine oil cooler. It's the first time that I came across a factory oil cooler. There's an aluminum cooler in front of the rad, flexible lines loop under the rad support and connect to hard lines that mount to an adapter between the filter and block.
Are they very common? I was considering removing it and keeping it, do you think it would be worth taking it off?
Kopper is offline   Reply With Quote
