09-04-2007, 03:51 PM | #1 |
control knobs
could someone enlighten me as to how a grown man removes the light control knob & assembly, the choke assembly, and the wiper assemble from the dash. It's killing me.
09-04-2007, 04:37 PM | #2 |
Re: control knobs
take the knobs off and they unscrew.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
09-04-2007, 07:14 PM | #3 |
Re: control knobs
I tried turning them but they wouldn't maybe paint on them keeping them stuck. thx will try again.
09-04-2007, 08:47 PM | #4 |
UCA63
Re: control knobs
The light switch has a spring loaded button on top near the back, when the button is depressed pull the light knob out,once removed the switch assy comes out from the back
The wiper knob has a set screw on the side of it ,remove knob switch comes out from the back choke cable has a 7/16 nut holding it in from the backside unhook from carb,remove said nut, the whole assy comes out the front cable and all. ps the nuts a b***ch to get to same deal with the throttle cable if you have one hope this helps T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
09-05-2007, 12:21 AM | #5 |
Re: control knobs
I came across a gauge panel in the junkyard that i wanted and the only thing holding it in was the choke bezel. I only had a screw driver with me and I tried for about 30mins using pieces of metal i found to pry that dam thing out of the truck. People walking by stopped to try to help me. I finally gave up and the next time I came back it had gone to the crusher, good riddance. I found another better gauge panel at the next junkyard.
09-05-2007, 05:42 AM | #6 |
Re: control knobs
thx everyone that will help alot. this is the best place in the world
09-05-2007, 06:45 AM | #7 |
UCA63
Re: control knobs
I could be wrong on the nut size could be 1/2 or 9/16
