Old 09-04-2007, 09:10 PM   #1
jor
Spindle Bearings
87 Suburban, 10 bolt Front End
I'm putting my front end back together with new tie rod ends, sway bar bushings and so on. I've got my inner and outer wheel bearings all cleaned up and ready to be packed. Now that I'm looking at the manual I see there are spindle bearings as well. Are these roller bearings that are supposed to spin free? Mine look OK but they don't move. Do you usually replace these spindle bearings? Thanks.
jor
I ANSWERED MY OWN QUESTION. I FOUND ANOTHER SET OF SPINDLES AND THOSE ROLLER BEARING ARE FREE. I'LL JUST CLEAN THOSE UP AND USE THEM INSTEAD.
jor is offline   Reply With Quote
Old 09-04-2007, 09:13 PM   #2
msgross
msgross's Avatar
Re: Spindle Bearings
I replaced mine... very easy once you have the right tool (blind puller from autozone). Cheap to replace too... They should spin though...
NAPA sells an entire kit that will have the thrust washer, bearing, seals and all.... I can find the part number if needed...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-04-2007, 10:46 PM   #3
jor
Is that tool one of the Autozone loaners? Also, I could use the part number. Thanks.
jor
Old 09-05-2007, 07:59 AM   #4
msgross
msgross's Avatar
Yep, blind puller with slide hammer at autozone was the best way to get it out, safely and easily too...
Napa part BK1 - $17.99 http://www.napaonline.com/MasterPage...+-+Front+Wheel
or the bearing only - brg b2110 - $11.49 http://www.napaonline.com/MasterPage...+-+Front+Wheel
the only way to get the plastic thrust washer was with the kit, good luck..
The Garage:
Old 09-05-2007, 09:28 AM   #5
jor
Thanks for the information. I'll pick up the kit and get the loaner.
jor
Old 09-05-2007, 07:00 PM   #6
jor
All done. I couldn't find one of those blind pullers and the Autozone pilot bearing puller was trashed. Anyhow, I ended up using a slide hammer and it got them out. Now I've got shiny new bearings! Thanks for the part numbers too.
jor
Old 09-06-2007, 08:24 PM   #7
msgross
msgross's Avatar
no problem... I didn't learn about the kit until I bought all the parts, then I had to take it all back...
The Garage:
