Old 09-09-2007, 06:00 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
What did you get done 09/09
WOW! I finally had a weekend that I did some "real" truck stuff. I have been scrounging parts to convert my 82 Blazer front clip to a 73-77 style front end. After many unsuccessful attempts I scrounged up what was "supposed"ust free core support. It wasn't!
I had talked with forum member Tony (texassquarebodies) about a hood, and he said he thought he had a good core support as well. I loaded what I had on a small trailer and headed to Rockwall this weekend.
After dropping what I had at Stoked Out and spending a few hours catching up on the latest with my buddy Keith (n2billet) we took off to Tony's little place in the country.
Tony met us at the gate of his shop with a huge Texas smile on his face. He shook our hand and right away we started talking trucks. When your standing in the yard of Tony's shop it's impossible to not talk about trucks. He has a HUGE collection of 73-87 trucks of all sizes shapes and colors.
We made our way around the immediate area going from one building to the next. Every building we stopped at had a huge stash of parts in it. Most are 73-87, but he has tons of other era cars and truck parts too.
After s trip to the fridge for ice cold Gatoraid, we watched will Tony lifted a 80 C/K Blazer on the back of his rollback wrecker. We inspected to core support and it was mint. Half an hour later it was on the ground and on the back of my trailer.
Before I was done I had scored a super clean 73-77 hood, a mint core support, a 73-74 grill, and a spare fender. After that we hopped in the single wheel crewcab he had just bought for dirt cheap, and took a tour of the yard. Tony's family has 90 acres there in Wills Point and it has a LOT of cars and trucks.
There is another chapter to this story that I will have to add along with pics when I get home.
Until then, what did you get done?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-09-2007, 06:37 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: What did you get done 09/09
Changed out the carb gasket but my motor still isn't running right. Going to try a different distributor and if that doesn't clear it up, an Edelbrock 1406 is going on since I don't have the time or the money to mess with the Q-Jet at the moment.
Pyrotechnic is offline   Reply With Quote
Old 09-09-2007, 07:07 PM   #3
ocbaud
Garage Queen Material
my interior is completely done now.
started up the engine.
that went, ok....
new oil pan gasket is leaking. i need to pull the new long tubes and tighten the bolts.
the new carb needs tuned bad. took a few minutes to get it to idle on its own.
the tranny cooler is plumbed and installed. it is nice
my neighbors down the street were outside and started staring at me when the truck was started. i guess open headers on a decent engine are kinda loud for a peaceful neighborhood?
ocbaud is offline   Reply With Quote
Old 09-09-2007, 07:38 PM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
i tried to fix my daily drivers issue of running ruff but that failed so i will just keep driveing it tell next week end when i get a chance to try again. ( It need a cap and rotor cause those are old and worn a bit. Plus my mixers off and timing most likely )
I did alltho buy another truck a 1986 gmc pickup 2 wd i dont know what i got it for but 150.00 bucks for a running truck that not to bad in the rust area. I could pass it up. ill post picture monday when i get it i already bought it have title in hand.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 09-09-2007, 07:45 PM   #5
bigblock73
yeller
bigblock73's Avatar
I worked on Yeller this weekend! Went to the painters shop and we re-hung and aligned the doors. Next up is re-painting the interior and jambs...then final paint and assembly.
I also worked on the Suburban, got the new head gaskets put back in along with the heads...just need to bolt up the million or so pieces I took off just to remove the dang things in the first place.
bigblock73 is offline   Reply With Quote
Old 09-09-2007, 07:51 PM   #6
jimmycrown
got new tanks hung and filled half way to check sending units to see if they still read corectly and there not went on ahead and por-15 the back half of the frame since the bed is off and getting sand blasted in the garage.then i get called into work midnite the extra money will get me a new set of duals.
jimmycrown is offline   Reply With Quote
Old 09-09-2007, 07:56 PM   #7
pcmcobra
pcmcobra's Avatar
changed the oil in the 86...
yard work...
that is all.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 09-09-2007, 08:59 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
New cap and rotor along with spark plug wires into the camaro this weekend. Got a timing gun and got it timed pretty good. Still wants to run ruff but not as bad. Hopefully get that fixed soon. Went to my buddys house and checked his new house out and had kinda a dinner bbq thing on saturday night. Other then that noting too exciting.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-09-2007, 09:54 PM   #9
bigblock79
67 Chevy Stepside
bigblock79's Avatar
tune up the 4x4 plugs and wires and cap and rotor. and rode the bike some today
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 09-09-2007, 11:09 PM   #10
82c10
needin' money
bought a 92 mustang gt parts car thursday, went to noble to thunder valley friday night, went to lawton to sooner motorplex saturday, went to church today, need to buy a car to swap some of the parts to
82c10 is offline   Reply With Quote
Old 09-10-2007, 12:04 AM   #11
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I did nothing to the truck, as usual.
My wife and I spent most of the weekend moving an 8X10 tin storage shed to a new location in the yard onto a new treated lumber floor setup. It was a lot of work, but I can have a real storage shed built in the location it left, so I can free up some more room in the garage.
There's so much stuff in there that I can't even work on anything right now. My goal is to remove everything from the garage that isn't related to working on cars and trucks. We'll see if I can actually do it. :-)
We also got to spend a couple of hours fishing today. We went with a friend and her son. He leaves for bootcamp in the morning, and wanted to do a little fishing before he leaves. It was super hot outside, and we caught our usual nothing. :-)
Slonaker
EDIT: A friend gave me some truck parts this weekend. He gave me some of the old Silverado trim off his '87 that he no longer owns. He says more is coming my way as soon as he finds it all. That's a good friend....
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-10-2007, 01:44 AM   #12
knightlife
Dark Heart Motorsports
knightlife's Avatar
I got drunker than cooter brown with 3 med chics on sat night... *thinx* uhhh...yea, we'll leave that there.
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 09-10-2007, 01:57 AM   #13
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I rewired the 2 outer clearance lights on my burb and now they flash with the front turn signals. Basicly all I did was cut the groun lead at both of the outer lights and ran leads from them to the turn signal wires and spliced them in. So now they flash alternatingly with the front turn signals.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-10-2007, 03:28 AM   #14
xtreme80
Wishin' I had more money!
xtreme80's Avatar
My buddy was in a motorcycle accident recently and has no transportation, so we cruised in my truck friday and saturday night with a couple ladies. Worked on saturday, busy day as usual.
This sunday morning my parents left for their vacation to San Diego, so I got the house to myself till Friday. So I pretty much sat my happy ass in the recliner all day and watched TV, checked this website occasionally, and now I'm about to go to bed.
xtreme80 is offline   Reply With Quote
Old 09-10-2007, 05:34 AM   #15
moneyeater
moneyeater's Avatar
My buddy and me fabricated some seatconsoles for the buckets and got the exhaust welded together!
Name:  Sitzgestell4 [320x200].JPG
Name:  Sitzgestell5 [320x200].JPG
Name:  Sitzgestell6 [320x200].JPG
Name:  Sitzgestell 11 [320x200].JPG
Name:  Sitzgestell+Gurt [320x200].JPG
moneyeater is offline   Reply With Quote
Old 09-10-2007, 10:27 AM   #16
Ric83
Ric83's Avatar
The family got together at my parent's house on Sat. to hang out with them and make sure my dad is doing ok after last weekend. Also helped my brother debadge his Envoy. Just spent Sun. at home with the wife and kids. It was good to just chill and relax.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 09-10-2007, 10:50 AM   #17
Blackstone
Blackstone's Avatar
Got my "new" truck home Sturday morning and, upon thorough inspection found no surprises. I replaced the bad temp gauge with good results and still need to replace the blown headlights, p-side seatbelt assembly and install the E-brake cable (included with the truck). Upon the forum's advice, I bought the '87 w/plow for $2k and I'm confident that I made the right call. The cab floors and supports look great, rockers and doors will need a bit of work come Spring. The ceremonial removal of the bedliner revealed an absolutely MINT bed floor and the fuel-injected 350 purrs like a kitten.
I'll be back later with pics.
Blackstone is offline   Reply With Quote
Old 09-10-2007, 01:29 PM   #18
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Kinda finished the drop-top Lincoln, pics here:
http://www.67-72chevytrucks.com/vboa....php?p=2351540
Also took said vehicle across state to watch the WMU Broncos first game for the season, on the way back had to drive straight through a raging thunderstorm that made even 18-wheelers pull over - let's just say that moments like that make me really appreciate the offroad LT tires I got on the car, I kept flying at 75mph and didn't even get wet Truck related nothing accomplished, but then again what needs accomplishing (front end rebuild) is a bit outta my price-range right now.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 09-10-2007, 01:35 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nothing on the truck as usual!
Went to the Midwest All Truck Nats and mowed....
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-10-2007, 03:16 PM   #20
Tink
Tink's Avatar
Pulled the 700R4 back out due to no 4th gear, found the forward sprag was to fault and burned up the 2-4 band and overrun clutches. Replaced and reinstalled - all gears now working! Accidently pinched some wires on re-install though, so had some unexpected re-wiring to do.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-10-2007, 03:21 PM   #21
jchav62
1962 C-10
jchav62's Avatar
I worked on my '83 on Friday. Wasn't getting fuel so I assumed the fuel pump went bad. Bought a new one, put it in and still nothing. I figured a fuel line was plugged or kinked so I crawled under the truck and messed with that for awhile. All was good. I took the pump back out and had my better half turn the key to see if the rod was moving... it wasn't... The fuel pump lobe on the cam went flat! Next weekend I'm installing an electric pump... I'm not really a fan of those but I'd rather do that than a camshaft r and r...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-12-2007, 06:08 PM   #22
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
I took my Charger apart......
Going to be my project over the winter.....and probably throughout the next year or two.....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
