Old 09-17-2007, 02:08 PM   #1
Alan in Florida
What's the lowdown on lowering?
I'm debating on wheather to lower my truck (68). Intrested in any and all opinions. I really don't want to slam it to the ground, just use the 2 1/2" drop spindles. Also, if you drop the front 2 1/2", do you drop the rear the same? I'm not seeing any kits to drop the rear 2 1/2". (I see 4" or 5" )
Alan in Florida is offline   Reply With Quote
Old 09-17-2007, 02:13 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: What's the lowdown on lowering?
In most cases no. It completely depends on the owner and the look they are going for. Most kits will allow for a little rake, a lot of rake or a level look. Rake meaning the front is lower than the rear.
Be sure to look at ECE: www. earlyclassic.com
Lots of great parts.
Do a search in the suspension section, and you will find a thread with pics of trucks and different suspension layouts.
By the way.... welcome to the board!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-17-2007, 02:41 PM   #3
70short
I believe that if you use drop spindles you need to convert to disk brakes.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 09-17-2007, 02:48 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
-Nate
Old 09-17-2007, 02:57 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
Use this link for stance photos.
-Nate
Old 09-17-2007, 08:22 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I will testify that ECE stuff is good. Their tech helpline is outstanding. When I received the wrong part, a phone call to them had the correct part in transit, along with the return label that I would have to have the get them to pick up the wrong part. No questions....just good service.
You will have to decide HOW you want to achieve your drop....springs, spindles or A-frames. Springs will be cheapest. Spindles will let you change from drums to discs. You can combine some parts to get it even lower. ECE will get you down by 3.5 inches with spindles and springs.
Member Nr. 2770
Old 09-17-2007, 10:00 PM   #7
67 cst swb
67 cst swb's Avatar
Check out this thread, I just went through some lowering questions... more about what looks right for my liking, but... hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=257959
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 09-17-2007, 10:15 PM   #8
Boog
laying low
Boog's Avatar
I've got the itch to buy the goods to lower my 69 step but I know I should wait until I get it all assembled to better determine how much drop I want. You just can't tell how much those nearly 40 yr old springs have sagged....
If 2 1/2" spindles get mine sitting like SeeTen and 70SeeTen's trucks then that's probably what I'll be getting. It's enough for me.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
