Old 09-27-2007, 08:18 AM   #1
trjohnso
Guest
Posts: n/a
4wd front axle
Someone told me you are supposed to be able to turn the front drive shaft by hand with the truck in 2hi, and the front wheels not locked? Mine doesnt what could be the problem?
Troy
72 K10 cheyenne
Old 09-27-2007, 08:22 AM   #2
Southedisto
River life......
Southedisto's Avatar
Re: 4wd front axle
np 203 tcase. or the tcase isn't in 2hi.
Southedisto is offline   Reply With Quote
Old 09-27-2007, 10:22 AM   #3
66skylarkpost
66skylarkpost's Avatar
Re: 4wd front axle
no , it shouldnt turn if you have a 203 , they use a planetary gear set , to be full time 4 wheel drive . unless its been converted or in neutral , the front and rear drives are linked . but if you have a 205 , it should spin freely .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
